285/65r20 with 3.5” lift - big enough tires?
joshsouth12
I’m looking at this size tire and either a 2” readylift level with UCAs or a 3.5” lift. I’m worried if I went 3.5” I’d also need larger tires to fill out the wheel well - anyone running that setup on stock wheels or wheels with nearly a +19 offset?
May only get one shot to lift/level for a while but don’t thing I can swing the cost of the lift AND bigger tires if they ones I’m looking at are going to look tiny with that lift.
And sorry if already posted - I’ve scoured both this forum and the suspension/exterior forums without definitive answer.
2021REBEL
I just installed the Bilstein 6112 kit on my rebel and I have them in place at the top setting which has levelled the truck 2inches. I am running 285x60R20 with 20x10 rims.
joshsouth12
Thanks - what’s the offset on your rims? My stock black 20s have +19
Lpsouth1978
I did a 3" front/2"rear lift using the Motofab spacers and put 295/65r20 tires on. My wheels have a +10 offset. Slightly bigger tire that you are looking at, but I think your 285/60r20 will be fine. I had to do a little trimming, but you may not have to with those tires.
joshsouth12
I did a 3" front/2"rear lift using the Motofab spacers and put 295/60r20 tires on. My wheels have a +10 offset. Slightly bigger tire that you are looking at, but I think your 285/60r20 will be fine. I had to do a little trimming, but you may not have to with those tires.
Thanks! Great looking truck. Quick question, your post says 295/60 but your sig says 295/65, can you confirm which one it is? Your truck is very much what I’m looking for so you may have settled me on the 3.5 lol
joshsouth12
Sorry, they are 295/65r20. Just double checked. Nice catch.
No problem! Any chance you have some shots from the front or a front angle? Trying to gauge the .5” difference in height of the 295s vs my 285s. With the offset I have on rims, I can’t go bigger it turns out, so if I want 3.5” lift ill be running them - just comes down to stance of mine…
