285/65r20 with 3.5” lift - big enough tires?
joshsouth12
I’m looking at this size tire and either a 2” readylift level with UCAs or a 3.5” lift. I’m worried if I went 3.5” I’d also need larger tires to fill out the wheel well - anyone running that setup on stock wheels or wheels with nearly a +19 offset?
May only get one shot to lift/level for a while but don’t thing I can swing the cost of the lift AND bigger tires if they ones I’m looking at are going to look tiny with that lift.
And sorry if already posted - I’ve scoured both this forum and the suspension/exterior forums without definitive answer.
I just installed the Bilstein 6112 kit on my rebel and I have them in place at the top setting which has levelled the truck 2inches. I am running 285x60R20 with 20x10 rims.
Thanks - what’s the offset on your rims? My stock black 20s have +19
I did a 3" front/2"rear lift using the Motofab spacers and put 295/65r20 tires on. My wheels have a +10 offset. Slightly bigger tire that you are looking at, but I think your 285/60r20 will be fine. I had to do a little trimming, but you may not have to with those tires.
I did a 3" front/2"rear lift using the Motofab spacers and put 295/60r20 tires on. My wheels have a +10 offset. Slightly bigger tire that you are looking at, but I think your 285/60r20 will be fine. I had to do a little trimming, but you may not have to with those tires.
Thanks! Great looking truck. Quick question, your post says 295/60 but your sig says 295/65, can you confirm which one it is? Your truck is very much what I’m looking for so you may have settled me on the 3.5 lol
Sorry, they are 295/65r20. Just double checked. Nice catch.
No problem! Any chance you have some shots from the front or a front angle? Trying to gauge the .5” difference in height of the 295s vs my 285s. With the offset I have on rims, I can’t go bigger it turns out, so if I want 3.5” lift ill be running them - just comes down to stance of mine…
