This looks good. I have the same tire size and will be using the sport laramie rims. I went with the Falken's because of noise. Thats debatable. I have the ORP as well and intend on adding the 2.5" motofab puck up front and possible the 1.5" in the back. Should give me less than a half inch rake. Will post for comparison. Tires go on this weekend and if i can find the time in two weeks we will see the lift.Hey all,
Had 285/60R20 KO2s installed on my stock 20x9s today. My truck came with the factory off-road package and they fit perfect. Slight rubbing on the fender liner at full lock. A quick snip with tin shears took care of that!
pics attached
View attachment 38496 View attachment 38497 View attachment 38498 View attachment 38499 View attachment 38496 View attachment 38497 View attachment 38498 View attachment 38499
You are going to need new Upper control arms. If you use 2.5” level plus ORG you are 3.5” lift on the stock arms. Sorry if you already knew this but I wanted to say something.This looks good. I have the same tire size and will be using the sport laramie rims. I went with the Falken's because of noise. Thats debatable. I have the ORP as well and intend on adding the 2.5" motofab puck up front and possible the 1.5" in the back. Should give me less than a half inch rake. Will post for comparison. Tires go on this weekend and if i can find the time in two weeks we will see the lift.
Looking forward to some picsI just bought the 2 inch Mopar lift. I also bought 295x60r20 Nitto Ridge Grapplers to go on my stock 20 inch Laramie wheels. It all gets installed next week. Very excited.
to the OP those look good. That’s the size I want to go next
