285/40r24 vs. 305/35r24
Complexeyedea
I'm looking to add a 24 inch rim with a street tire, maybe atturo az800. Wheel is 24x10. Either a offset of +31mm or + 19mm. I have a 2020 limited ram with air ride. Does anyone know if I will have rubbing issues at 285 40 24. Or should i stay at 305 35 24? Would the +19mm offset be better to keep it closer to stock? All help is appreciated.
Tia.
Ellisstrong
Atlanta Ga area
I believe either of those will work with the +19 as they aren’t much taller than stock. I have 26x10 and 315 40 26 that fit with just a level and some minor trimming
Complexeyedea
Ok, I'll order the +19. I was worried the 285 40 24 would rub without a level. I wasnt trying to level anything but if anyone else has ran this size before all help apreciated.
Caballonegro
I have 305-35-24 on 24x10 with a +15 offset. I am riding on a air stock suspension. I do have 1.75" spacers and the only place I rubbed was on the inside of the my front mudflaps. I cut the inside section off of the mudflaps, about 2 inches and you can't even tell I did that. I eliminated 100% of rubbing.
Complexeyedea
Well I went to order the 305 35 24 +19 today and they are sold out. So note the only wheel woukd be +31mm. Was thinking of jst ordering this with spacers but ive never used spacers before. So it's up in the air. Thank you with your input, I do really appreciate it.
Complexeyedea
Ordered +31, well try to mount regularly and go from there. Hoping they go without needed spacers
1172scorp
How far out do your wheels stick out from the fender? I was looking at the same wheels but with the machined face. I want them to be as flush as possible.
Caballonegro
They would be very flush if I didn't have the spacers.
