22" Tire Size Recommendation- 3 Options?!
I take delivery of my 23 Laramie Night Edition (non air ride) on Monday 7/31 with 22s and the GY Touring Eagles
I want to replace them ASAP with something "bigger" without lift/leveling and minimal to no rubbing.
Hours of reading threads here I can't seem to come to a conclusion on the best size.
Does anyone have the experience to share a comparison between the following 3 sizes?
275/50/22
305/45/22
33/12.5/22
I live just outside of Philadelphia and will be doing mostly highway and city driving with 2 kids. So looking for safety and longevity.
Here is what i am considering:
1. Michelin Defender LTX M/S (275/50)
2. Toyo Open Country AT III (305/45)
Any insights or experience sharing would be greatly appreciated.
Just installed new terrain contacts A/T on my ram limited 275 50 22 they ride beautiful and quieter than my old bfgoodrich advantage T/A’s stock size. Got a 1/2 more sidewall with continentals and I notice a smoother ride, absorbs bumps better not that the old ones were bad but the continentals are better. Was worried about highway noise since 95% of my driving is on highway doing 70-90mph less vibrations too at 80mpg which I had vibration with old tires which Is normal when tires wear, it’s smooth like if it was driven off the dealer again. I did consider the toyo at3 for looks but for my needs these are perfect and still have mild agressive look. I’m happy.
275/50/22
305/45/22
33/12.5/22
When changing tire sizes, are we maintaining the original tire diameter? If the diameter is being changed, does anyone give consideration to computer/speedo calibration? Can the Ram electronics be calibrated "at will", or is an external programmer necessary? Does anyone care if speedo is as much as 5 mph "off", especially when being tailed by a cop?
Alfa obd to adjust speedometer.
I went to a 305x45r22 and at highway speeds my speedometer was showing 2-3mph slower than what I was actually doing.
I got my 33’s a couple years ago. Finally updated my size today using jscan (I have an iPhone). The dealer will charge a couple hundred bucks.
Usually when going a bigger tire, the speedo will be faster then actually doing, so that 5 mph with a cop won't matter and maybe even save you. :ROFLMAO:
It’s the other way. The speedo will read lower than your actual speed. For instance with my tires, it was about 2 mph off at 60.
