gskowronek
- Mar 22, 2024
I seriously doubt it. The biggest difference is the canbus. It will not be plug and play for anything going from 2025+ to 2029-2024 and the other way around.Does anyone know if this is possible? Put 2025 LED Limited headlights in 2024 Limited?
Size looked the same
Assuming they’ll fit (looks like you’d need the new grill and filler panels), you can probably get the lights themselves to work, but you’ll lose the ability to have adaptive feature.Does anyone know if this is possible? Put 2025 LED Limited headlights in 2024 Limited?
yea I don't think the grills/filler panels are interchangeable either, The 2025 has a taller grill. you'd have to swap the entire front end including the bumper.Assuming they’ll fit (looks like you’d need the new grill and filler panels), you can probably get the lights themselves to work, but you’ll lose the ability to have adaptive feature.
I also have 2025 Rebel and wish it would work. On a another thread it's been said we would need a different grille,although they do look the same size. The big issue is that the interior would have to be removed to install the required harness/module. Hopefully the aftermarket will come up with a solution.I have a 2025 rebel I'm wondering if those headlights from the 2025 tungsten or rho will fit the 2025 rebel? They look like they will size wise.
They really messed up the rebel with this rho thing. I had a 2024 that was totaled so I ended up with this 2025. I like the truck but I liked my 2024 better!I also have 2025 Rebel and wish it would work. On a another thread it's been said we would need a different grille,although they do look the same size. The big issue is that the interior would have to be removed to install the required harness/module. Hopefully the aftermarket will come up with a solution.
Try it first, may have computer issues.I have a 2025 rebel I'm wondering if those headlights from the 2025 tungsten or rho will fit the 2025 rebel? They look like they will size wise.
Are the rebel ones not LED?I have a 2025 rebel I'm wondering if those headlights from the 2025 tungsten or rho will fit the 2025 rebel? They look like they will size wise.
noAre the rebel ones not LED?
