2025 to 2024 Limited headlight swap
gskowronek
Does anyone know if this is possible? Put 2025 LED Limited headlights in 2024 Limited?
Size looked the same
I seriously doubt it. The biggest difference is the canbus. It will not be plug and play for anything going from 2025+ to 2029-2024 and the other way around.
Assuming they’ll fit (looks like you’d need the new grill and filler panels), you can probably get the lights themselves to work, but you’ll lose the ability to have adaptive feature.
yea I don't think the grills/filler panels are interchangeable either, The 2025 has a taller grill. you'd have to swap the entire front end including the bumper.
I have a 2025 rebel I'm wondering if those headlights from the 2025 tungsten or rho will fit the 2025 rebel? They look like they will size wise.
I also have 2025 Rebel and wish it would work. On a another thread it's been said we would need a different grille,although they do look the same size. The big issue is that the interior would have to be removed to install the required harness/module. Hopefully the aftermarket will come up with a solution.
They really messed up the rebel with this rho thing. I had a 2024 that was totaled so I ended up with this 2025. I like the truck but I liked my 2024 better!
