2024 Ram 2500 secure gateway module location
Rebel_2025_GA
Going to add some items and will need the 4 digit pin. I have a bypass cable and OBDlink MX+, and have the AlfaOBD app but I can't locate the SGM ,
spent a few minutes digging around under the dash and cant see it.
Anyb help would be greeaat
You don’t need the 4 digit PIN for anything on your truck.
The SGM is behind the instrument cluster. Use the kaodtech style bypass instead, and you won’t have to mess with accessing the SGM.
I'm brand new to this so I really appreciate the info.
Sorry to revive on old thread. I’m having trouble finding a know good alternative to the kaodtech security bypass harness. That and the edge tuner one (same style) are out of stock everywhere.
What if we already have the 12+8 and want to get something accomplished and you can’t get the Koadtech still?
On an HD?
Pull the instrument cluster (EVIC).
If @Jimmy07 can't be reached or doesn't have the parts to build and supply one (heard the OBD heads were suddenly hard to get), Infotainment sells them at about the same price.
On an HD?
Pull the dash cluster.
Yes, 3500. I did just pull the cluster, not seeing where the connections go.
Found an open plug tucked behind the start stop, but it’s not the right connection
Black box behind that wire bundle closer to the firewall. There are 2 plugs to pull that will mate to your 12+8 cable.
If you buy it from OBD Genie, it’s free shipping. Placed order.
Opened up the dash again, but I can’t get my hands in there to get the damn plugs out.
For what it’s worth I got the email today that they’re back in stock at Koadtech
