2022 Limited Granite Crystal - Detailed
CharcoalRamKS
I had to make another post after having some time this morning to get this thing detailed up in the garage. Got the level, links, and tires installed this week. Appreciate all the ideas on this forum!
Josh24
Nice additions to the Limited! I put on the 285/55/22's as well and been debating a leveling kit as well. After install did it leave you a bit higher in the front or did you keep a bit of rake? Also, any changes in ride after installing the kit that you've noticed? I'm happy with the ride on the 285/55/22's and they fit without any rub on stock suspension but wanting to get a bit more clearance and even out the stance some. Have heard nothing but good things on the ready lift kit but have been cautions so far with modifying the air suspension. Thanks!
RcCola
nice. What tires are those? 33 ridge? Why lvl kit? And what did the links do for ya?
RcCola
Got my 23limited yesterday and just put in tint. Tires next. Was thinking just 33’s.
CharcoalRamKS
The ready lift kit works great. There is an ever so slight rub at full lock in reverse. I just bent the plastic back a bit to fix that. Stance is great, but I did add the revel links in to adjust if wanted. It’s a cheap and easy insurance policy if you want to add back in some rake. I love how it sits, looks good, feels good.
CharcoalRamKS
Ridge 285/55/22 = 34.3
levek kit to make stance better and bring the front up.
I have the links installed and basically zeroed out. But if you want to add any rake you can now control that and customize it by turning the links.
