2021 Won't Start - Brake Pedal Can't Be Pushed
mariuszz
Ran an errand this morning came back parked thecar and few minutes later when I decided to move it to another spot, it wont start. The brake pedal is hard and I can't push it down. Also the remote start will not work. I tried jumping the truck but that didnt work does anyone have any advice? Thanks
Rick3478
NW OH
First thing that comes to mind, there was an issue with some of the power adjust brake pedals where they can unscrew too far and jam up. There's a TSB on here somewhere I think. Don't know if it prevents remote start but you wouldn't be able to shift out of park anyway if you can't activate the brake switch.
Snowfox
BC Canada
My battery died on the weekend, and the brake pedal was hard as a rock. When I got it charged up again, it was back to normal.
crusher
st-jean quebec canada
whats the specs of your truck ? year? you mention you tried to jump it, so i imagine your battery is dead? or you still had power? if battery dead, some here on this forum were not able to jump start their truck when the battery was dead, they replace the battery and everything was back to normal after
Richard320
Had that happen to me once. I just put all my might on the brake pedal and then it started and the pedal felt fine again. Just the one time over a year ago and no problem since. No clue what it was.
bubonic_bonnie
Did you ever figure this out? I'm currently dealing with the same thing
M3forged
When it happened to me I was doing some wiring and messing with battery connections. I'd start there, if a jump won't work try replacing it. Good luck!
bubonic_bonnie
I have a 2019, I was able to charge it enough to start it. The screen quickly flashed and said to service my parking brake, and then later said to get my ECM maintenanced. It's so strange because it was running perfectly the night before
