2021 Rebel 5.7 awd in 2wd mode?
R.A.M
I’m not seeing it on your window sticker. In order to have 4-auto on a Rebel, you have to get the electronic shift-on-demand feature. All I see here is the eLocker.
Sorry I know it's a bad picture. Right under the 1st category, Standard equipment
ferraiolo1
North Central PA
Optional equipment can replace some of the standard equipment.
downsc123
It says shift on the fly part time transfer case . That doesn’t have 4auto . You should have 2hi , 4hi and 4lo .
Correct. The AWD option is an extra cost
R.A.M
Ok, now I understand the difference. I did some reading, the part-time is the 44-45 and the on-demand is the 44-44?
DIRTRIDER
Don’t know if this makes any difference , but I always shift my Rebel in/out of 4wd with trans in neutral at a slow crawl speed and when going back to 2wd after shift light goes off , back up about 20 feet to make sure system isn’t bound up. Goes back to my old Jeep’s , only way you could do it.
ferraiolo1
North Central PA
You don’t have to do that with a modern tcase
Unless you’re going into 4low
