2021 Laramie 1500 4x4
Sarge48
Ordered a 2021 ram 1500 Laramie will put a 2inch level kit on it. Am going with the toyo RTs. My question is with the leveling kit should I go with 275/70/18 or 285/75/18 or maybe 295's. Currently have the 275/70/18 on a f-150 with no level and like it but with the 2in level on the Laramie would the 285's or 295 be a better look not sure which way to go any pics and or opinions would be appreciated Thanks
Sarge48
Not looking for the biggest just a tire that would fill up the wheel well with a tire that's not to big but not to small Kinda afraid the 275/70 may be a little on the small side with the 2inch leveling kit but definatley not a great big tire which would be give a negative hit on mpg.i reckon set that would "look right"
PorBoy
5thGenRams Supporter
Millville 08332
Do the 295/70 on there as the RT is already an aggressive looking tire and would give the filled look with being stuffed in there.
PorBoy
Millville 08332
I’m saying the 295 was a filling look and it was close to the LCA, but if I were in your position I would do the 295/70...
Sarge48
Ok thank you sir. One more thing is how do you recalibrate all this? ( I’m very green at this as you can tell)
Rollint
I think rough country makes one that is like 150 bucks. You'll wanna have a GPS speedometer on your phone to make sure your adjustments with the calibration tool, which you'll plug into the vehicle (not an app), is reading correctly. For example, many folks with 35" tires recalibrate to like 33.7" through the recal tool.
