My truck is at the dealer now for corrosion warranty repair.Does anyone know if anyones had this corrosion issue on a Ram DT before? Any chance Dodge will make good on it or do I have to go spend a mortgage payment on a new fiberglass hood b/c they didnt paint it properly?
That's God-awful ugly. Looks like they formed it from cardboard and then glassed over it.Dunno about Mopar but here's one I did find that has a built in ram air tunnel, fiberglass & resin blend:
RAM 1500 SSK Style Ram Air Hood; Unpainted (19-25 RAM 1500, Excluding RHO & TRX) - Free Shipping
FREE SHIPPING! Stylish Sporty Hood. Take a drive in your RAM and rock a look to remember with this SSK Style Ram Air Hood; Unpainted. A major upgrade from yourwww.americantrucks.com
Take a look at Ford Explorers. I've seen their hoods with corrosion, being new on dealers lots.It seem that FCA needs to hire some engineers that understand galvanic corrosion. The Wrangler JLs have this same corrosion on doors, hoods and tailgates. Mainly near the hinges which are different materials than the other body panels with no insulating barrier between. They are assembled bare and then painted.
I bought my 2020 Rubicon new in June 2020 and it was always garaged and never driven in snow or salt. It rarely was driven in the rain and still had this issue when I traded it on my Rebel GT. Nearly every Wrangler JL has it in some form. The corrosion warranty on the JL is 5 years and unlimited miles. It appears it is the same on the DT trucks.
There is a TSB for this issue on the Wrangler. They have addressed this issue, unfortunately not until 2023 so there are many JL corrosion issues.It seem that FCA needs to hire some engineers that understand galvanic corrosion. The Wrangler JLs have this same corrosion on doors, hoods and tailgates. Mainly near the hinges which are different materials than the other body panels with no insulating barrier between. They are assembled bare and then painted.
It does, but I haven't seen a '15+ F150 with corrosion yet, have you?What's funny is when all the Ford guys try to say how their trucks won't rust out because of aluminum bed. Cause they don't know that aluminum corrodes as well.
I don't own a Ford, and do t go around inspecting them. So no, I haven't, because I'm not lookingIt does, but I haven't seen a '15+ F150 with corrosion yet, have you?
Should be covered. You need to take in and then pictures need to be taken and authorized by the mother ship.I just noticed this on my 2022 this morning. So is this covered by warranty?
I don't either, but the Rams with rusted out wheel wells are pretty damn apparently as you drive around...I don't own a Ford, and do t go around inspecting them. So no, I haven't, because I'm not looking
Amusing, The Jks all had this issue, I thought they put a gasket between door and hinge in 2016 or so to stop itThere is a TSB for this issue on the Wrangler. They have addressed this issue, unfortunately not until 2023 so there are many JL corrosion issues.
Most of that is just lack of cleaning by the owner.I don't either, but the Rams with rusted out wheel wells are pretty damn apparently as you drive around...
Many folks cover them up with those huge, gawdy fender flairs too... that's a dead giveaway...
Just wash your truck regularly and make sure to get up inside wheel wells where the rust tends to start.I'm afraid to put flares on mine. My '09 had them and I took them off to replace busted manifold studs and they were full of rust under the flares
Usually it's from dirt/mud/salt(in winter) sitting in top of the lip for the wheel well openings here the screw for the flares are. The screws remove somebody the paint when installed, losing the protection.I thought perhaps water got inside the flares and rusted from the outside in. It would be easy enough to keep the wheel wells clean
