2020 1500 airride Limited with 35" on 22x12 -44 offset
Here's 35x12.50 on the factory wheels, no spacers no lift. I do have the air ride with the offroad package. I have no rubbing in the aero mode and obviously none in normal and offroad. It does rub a bit at full turn in the entry mode. But I almost never have it in that.
Really no lift or level?
Yup! no lift no spacers! remember though it has the air ride AND the Off Road Package. So it has the same suspension as the Rebels that have air ride which sit higher then the other trims that do not have the off road package. :)
So rebel with air ride sits higher than limited with air ride?
I just want a clear answer from someone that can answer this confusing question for me. Will 22x12 -44 with 35" fit on a ram 1500 limited with air ride loll
It depends on how the limited was optioned. If it does not have the off-road package then the rebel sits higher. If the limited has the off-road package then it has the same suspension as the Rebel and has the same height. That's is taking into account that they all have the air ride.
@Nick57 your wheel/tire setup is just perfect, and exactly what I need. I currently have lame stock 20x9 Premium Painted wheels, but the rest is the same, 2019 Larami with ORP and air. I need that beefy tire so I can air it down in remote places. Is your wheel 18"? Do you know any more details? offset, etc. I'm having serious problem with finding 18" wheels since they may rub brake pads and nobody knows what should be the offset especially with bigger tires. Additionally I was told that maximum is 32.1. Looks like I can go 35 but on 20" or 18"?
Hi Crazydrive, The wheels are my factory 20" wheels. the M/T Baja Boss AT's 35x12.50r20 is the tire. they run around 34.5" tall. :) You can def run 35's as long as you stick with a 9" wide wheel with a low offset and higher back spacing around 5.75" :)
I have a 2020 Limited Air Ride with a Rough Country lift. Going with the Nitto Recon Grappler 35-12.5-22. I hope there won't be too much poke with the factory wheel. I hope it looks like yours Nick57.
Thanks jpesaturo! Your tires should have about the same poke as mine do. Make sure to post some pictures before and after the lift is installed! :) Don't forget to tag me.
Thanks @Nick57 ! After all I went a bit different route because I don't need 20" wheels but your info gave me confidence in wide selection of options. I need extra cushion when off-roading (wash boards, small rocks) so I'm totally happy with 18" rims, which I found for just $300, so I downsized here and gained extra 2". I wanted KO2's and the biggest matching 9" wide rim were only 33.2. I think it's not so bad because that is almost extra 4" on the tire. Yours definitely look more bad a.ss :)
What surprised me, checking speed with GPS the speedometer shows EXACTLY the same speed. Ok, there is 0.2 - 0.3 mph difference. GPS shows a pinch higher speed than the truck. How is that possible? I measured my previous tires before taking them off and they were barely 31". So far I didn't flush the computer with new settings. I hope it will not mess up transmission or something else in the long run.
That's awesome!!!! Post some pictures! As far as your speedo, if it's that's close and shifting when it should I would leave it alone. It won't hurt anything at all.
