2019 Ram 2500 Laramie Bed Lights
Ccome15
Hey everyone, new to the forum. I bought OEM bed lights for my 2019 Ram 2500 Laramie. Followed the instructions running the wires and connecting to the BCM. Instructions say plug DG/WT wire into C6 pin#26 (which has no wire but also has no male prong on the BCM when I pull the connector), and C1 pin#5 which has an existing tan wire with orange tracer. After days of research I can’t find anythingsaying different, so I went ahead and and plugged the DG/WT in C6 pin#26 and spliced the second wire to C1 pin#5. Well as long as the truck is on the lights are on and when the truck is off they turn off. Neither of the switches, the bed switch and cargo lamp button affect the bed lights. They just stay on.
Saying all that, I know the pins used are wrong. Does anyone have info on the correct pins to use?
Got the wiring diagram from the dealer today and looks like the 2018 C6 pin 26 (Cargo lamp switch signal on circuit L26) is the equivalent to my 2019’s C7 pin 16. And then the 2018 C1 pin 5 (Cargo lamp driver on circuit L19) is the equivalent to my 2019’s C3 pin 17. Can anyone look at the snapshots of the wiring attached and confirm that I’m not just looking at this completely wrong?
