I just got my Big Horn in September, and my tailgate just suddenly stopped opening. I tried locking and unlocking several times, and it seems to just be stuck in the locked position (or just closed). Anyone else having this problem?
I have the same problem with my 2019 lonestar 1500. It just wont open sometimes, i cant think of any reason on why or when it happens, so I took it into the dealer, they cleaned it and greased it . Gee thank you i would have never thought of that.I just got my Big Horn in September, and my tailgate just suddenly stopped opening. I tried locking and unlocking several times, and it seems to just be stuck in the locked position (or just closed). Anyone else having this problem?
Hi @Djchrissypoo & @brian42 - If you experience this concern any further, please be sure to follow up with us via private message. I would like to make sure we have this documented and provide you with the additional support of a specialist if you end up working with your dealers again.I had the same problem. It started a few months ago.
Tailgate used to open just fine then it felt stuck. I had to push in on the tailgate, press the button, then the gate would open.
Took it to the dealership last week for them to look at several things, including this.
They couldn't find anything obvious but inspected and cleaned the grounds (per the tech manual). Now the tailgate opens just fine again.
Hi @Chuck19 - If it would be of interest, I would be happy to escalate a case on your behalf as you work with your dealer. This will provide the dealership and yourself with an individual who will review your concern, then assist you and the dealership in exhausting all available resources to have the concern addressed and resolved.I have had a similiar issue and it happens off and on. I thought that I hadn’t unlocked or something and that isn’t it. So now when it happens i just push on the tail gate like i am closing and then it opens right up. Not sure what the deal is but will take it into the dealer when i get a chance. However if someone figures out what the deal is i am all ears on a solution.
Same issue with my 2019 Laramie. I cannot get the tailgate to open. This is an issue with my tonneau cover since I cannot access the bed at all.
My tailgate is experiencing the same issue of random times it won't open/unlatch. Started doing this last month. Wondering if I need to fork over the $$$ for an extended warranty.
Hi @9thRamMan - If you would be willing to address this with your Ram dealer, I would be more than willing to escalate a case on your behalf for further support through that process.2019 Bighorn having this same issue. I took the tailgate panel off to see if there was anything that can be lubricated but it seems like the latches are solenoid motors for each side. Im going to spray some wd40 and see if that makes a difference. I do haul dirt from time to time so I'm thinking dust could be holding these "little" motors from proper operation. The push on the tailgate works but only half of the time. RAM, this is clearly an issue that needs addressed.
I have a 2019 I ordered a year ago. It has the same problem of occasionally having the tailgate not open with the manual latch. I took it to the dealer but they of course couldnt duplicate it and I got the usual grease job. I have found that if you pull the latch and at the same time bump the gate "in" with your hand it opens. I have also had issues with it shutting and not shutting the cab light off and I get the alert on the dash. I have to go back and really slam it hard and that gets it.
Do you have a classic Big Horn (4th gen)? Because on 5th gens, you don't pull anything to open the tailgate. It's more of a switch you push. It's not a mechanical lever like on earlier pickups.I am currently at my dealer for exactly this item. After driving, if you get out if the truck (after turning off) and go to open the tailgate, it just clicks when you pull the handle. If you push in on the tailgate while pulling the handle, it will open. Once it opens the first time, no problems on successive pulls.
I'm wondering if it has to do with the lock mechanism of some sort? Unfortunately, the diagnostic is going to cost me $120!
