Ortiz7983
- Nov 6, 2018
Did not flush. I have a leak on the hose that leads to the oil filter housing.Did you flush your system, or are you trying to top it off?
This is good, and another alternative is to let all the coolant drain and re-add it using a vacuum coolant filler tool. Even those aren’t perfect every time though.Fill it through the radiator, then top off the reservoir if it needs it after you’ve cycled all the air out
