2019 3500 6.2 Windshield Leaking and Layers Penetration
astroalan
Hey all! I have tried to find information on my secondary issue to no avail. The primary issue is water leaking from the center ceiling group (only noticed while driving). But I also believe my windshield to be leaking as I have had to wipe a solid sheet of water droplets from the entire inside of the windshield on multiple occassions. Also, I have experienced an issue that I have found no other information on--water penetrates the front windshield layers and fogs the windshield so that I cannot possibly wipe it away. Only when the windshield gets hot does the trapped moisture evaporate. Has anyone else experienced this? The water coming inside the cab may indeed be from the cab lights but I am not sure. However, I do not believe this would explain why the entire windshield is covered in a solid sheet of water droplets on the inside. I have replaced the 3rd brake light foam with a rubber gasket so I know that is eliminated. I have sent a message to RamCares and got nothing. Any thoughts, insights, or recommendations are welcomed and appreciated.
Oh, ok. I did not know this was only 1500’s especially with the brand-wide leakage issue. Thank you for the direction.
