  • We have been battling an on and off issue with registration verification emails not being sent out with certain users. We have finally got the issue resolved so if you have tried registering for the site but have not received a verification email, just request another verification email when you log in and you should now receive it. If you still don't receive the verification email, send us an email at [email protected] and we will get it resolved for you. Thanks!
2 cents on glasscleaner
Rsorrell2
Chula Vista CA
There are a lot of glass cleaners out there (windex, invisible glass, armorall, rain x, etc.) and I have probably tried most of them.
but I have found that using windshield washed fluid ($2-$3 a gallon) works just as well, is cheaper and since it means you need a spray bottle to use and you just refill as needed you are a little eco friendly.
you probably have some anyway to refill the washer reservoir.
you can also add Allittle bit of vinegar of you need to. It is also ammonia free so safe for tinted windows.
just my 2 cents.
Cajun_
Louisiana
Doesn't really matter what you use so long as it doesn't have ammonia in it.
cervelo15
Lehigh Valley, PA
I have a small spray bottle that i keep in the console which is a mix of 90% isopropyl alcohol and distilled water. Works great cleaning the windows while waiting in the pickup line at my daughters school.
HEMIJAKE
Potter County, Pa
just my 2 cents.
Interior too or just exterior? I've used iso alcohol before but this sounds like a good alternative too.
Cajun_
Louisiana
I use it for both inside and outside.
so if you really care you should used the correct products for each different thing along with the correct towel. Washer Fluid will damage tint and any trim/leather it may get onto. Outside is whatever, do what you want.
66Fuelie
5thGenRams Supporter
Same here except I add a cap full of vinegar. Works great.
Tom
