Any rubbing with that wheel/tire setup? I'm between 20x9 -12mm w/ 35x11.50 orrrr 20x10 -24 w/ 35x12.50. But I'm worried about the extra offset and width leading to too much rubbing.
It’s a dealership in Suffolk ny. Browns truck center. They have a local shop do it. 2 inch rough country preload spacer. With that wheel set up they do some trimming.
If you close by the cab you’ll see the trimming.
I wouldn’t necessarily say way lower, personally I think the red looks better, but I would definitely want the upper control arms changed out on the black one with the ORP
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
