19 Limited with oem 22 or go with 20
AtlasRam1500
Looking for advice, i have a 19 Ram Limited with the Air susp. it has the oem factory 22's. i'm planning on going with 35's or a metric tire that is close to 35 inch tires . Tire choose will be the Nitto Ridge Grappler. If i decide to go with the 20's my wheel choice is Fuel Rebel D680 in.
two question.
would i even notice a different with a 20 comparing it with 22 on the air susp.
is there any advange or disadvange or the mertic size tire compare to i know they are close to size
285 /55/22
285/65/20
35/12.5/20 0r 22
BeauxXL1200
two question.
285 /55/22
285/65/20
35/12.5/20 0r 22
Sorry I can’t answer your questions, AtlasRam1500. I have a 19 Longhorn that doesn't have air suspension. I put 285/60/20 Ridge Grapplers on the stock 20 inch wheels and I like them. The ride is just a smooth as stock, very little increased road noise, but I did lose about 1 mpg.
AtlasRam1500
thanks
Blkshrpi
two question.
285 /55/22
285/65/20
35/12.5/20 0r 22
You figure it out? Looking to do same but don't know how it'll work with my air suspension.
securityguy
North Florida
If you're going with a R edge Grappler, for any AT tire, I'd go with the 20's and not the 22's
AtlasRam1500
I stayed with the OEM 22 and when with Nitto Ridge Grappler 285/55/22 also installed the daystar spacer with revel performance links, No problems sight rub on normal height when doing hard turns, i would have like to try 20 but i went the cheaper
AtlasRam1500
