13 wides with 3 inch lift?
Yeti's_Ram
New to the forum. I'm attempting to put a 3 inch suspension lift on my 2020 rebel and wanting to go with a 13 inch wide tire. Either a 325/65r18 or 325/60r20. Has anyone had any experience with this and if so what offsets were you running on your wheels?
ElkoNV
My dog thinks I’m cool.
NV
Welcome to the forum, that is a wide tire. Hopefully, some members can chime in with experience.
Gandalfgrey
LaPorte, Texas
I run a 325/65/18 goodyear territory from a factory TRX so the wheel is very close to the factory Rebel offset but 9" wide , the tire mesures 34.6" by 12.8" wide that put the tire right on the upper control arms but no rub on the front rear splash guard until i installed a 1.5" wheel spacer then i had a little contact on the splash guard but all else cleared great i removed the splash guard & cut the little metal bracket off . i have the air ride & using Revel level links set at probably 1.5" so it didn't mess up the ride.:alien:
