Don’t you have one on top of your center stack?there are no 12v power supply anywhere on my truck
400w is not a lot of power, slightly more than 1/2 amp.
Thanks, I now remember seeing it there now, my though was it would be convenient for radar detectors.
Yeah what Eighty said! Should have one above radio. I thought the same thing. Until I tossed my sunglasses up there and noticed it lol.
Thanks for the amperage correction, I’m not sure what I was thinking . I forgot to multiply by 4 for every 100w400 watts is 3.6amps at 110V, but the issue is more likely the current spike required to get the compressor started. Betting it's tripping a resettable fuse. Out of curiosity, did you try running the compressor without being attached to the tire? I kinda doubt it'll make a difference, but I'd try it.
Remember, the center stack 12V only works with "key" on. U would have to go to yer interior fuse box and change setting on fuse to have the socket have power all the time.Thanks for the amperage correction, I’m not sure what I was thinking . I forgot to multiply by 4 for every 100w
It’s an air compressor for blowing up floats at the beach. I did turn on pump before connecting to floats400 watts is 3.6amps at 110V, but the issue is more likely the current spike required to get the compressor started. Betting it's tripping a resettable fuse. Out of curiosity, did you try running the compressor without being attached to the tire? I kinda doubt it'll make a difference, but I'd try it.
I have one of these that runs off 12v instead. It was like 15 bucks on Amazon and I use it to fill up rafts and such on my boatIt’s an air compressor for blowing up floats at the beach. I did turn on pump before connecting to floats
I have an inflator for my air bed that runs off 4 D cells. It's great when the tent is some distance from the truck. It is also really handy for coaxing lethargic barbecues into life.I have one of these that runs off 12v instead. It was like 15 bucks on Amazon and I use it to fill up rafts and such on my boat
I don't know what your vehicle is but not all of the AC converter were 400 watt some were only 100 watts.
My truck is over a year old and haven’t used the 110v outlets.
I have been carrying a 12v dc pump in the Rambox to air up the coil spring airlift bags for towing or carrying heavy loads, I was going to use the pump the other day and there are no 12v power supply anywhere on my truck, I either have to connect directly to the battery with jumpers or use my emergency booster power pack. This is weird, my first vehicle ever without 12v outlets. Many USB, USB C and 110v but not a single 12volt outlet, the world is changing!
Thanks, Yes I do, I had forgotten about it, someone reminded me about it in an earlier post.You don't have one on top of the dash?
