★ Jake's Max Steel HK REBEL 12 ★ Prodigy 18's
$12
noticed a reduction in cabin road noise (y)
push pins attach to 5 existing holes across lower leading edge of box
fyi > deleted on builds after mid 2018
If these go between the cab and the bed, I have them on my rebel, but my build date was 1/22/ 2019
So not on each side? but runs the width of the truck?
I'll have to look. I don't notice that much cabin noise.. In fact this truck is sooo quiet compared to my tundra.
Jake’s Rebel looks awesome. Question to Jake and any others who might know the answer. I’d like to put a black shackle on my receiver hitch like the one in Jake’s pics. But the truck is a tight fit in my garage as it is. Might be two or three inches between the back of the truck and the garage door when the door is closed. And that’s pulling into the garage as far as possible. Does anyone know how much the shackle sticks out from the receiver hitch when installed?
Thanks for any help in advance.
This one doesn't stick out that far and you can get a Heavy duty tow strap. It's not as good looking as Jake's red one, but I'm pleased with it.
Buckle up, ignition to run (don't start), let cluster boot up, unbuckle/buckle 3 times. Turn ignition off...chime will sound, mission complete.
tailpipes/clamps/resonators SATIN BLACK
$527.88 @DiscountTire shipped w/tax & 108 to 77.8 hub centric rings
+6m inside
+32m outside (1.25")
IMG_2821.JPGIMG_2832.JPGIMG_2838.JPGIMG_2840.JPGIMG_2829.JPGIMG_2822.JPGIMG_2823.JPGIMG_2856.JPGIMG_2850.JPG
5G RAM Redeye - 3D resin custom center cap inserts x4
$19 shipped via Ukraine
GO RAPTORS!
smoothed out the front caliper casting ridges
