Thanks!Here is the info from another member.
I ran into that same issue. I took one of the original screws to the hardware store and found something that was very similar. Not exactly the same but close enoughI went to install my rear liners today and the 2 screws I bought were too big. The part number is written as 0651 2919 AA but they are obviously different than the existing screws. Anyone else run into the same issue? Or should I just go to the dealer and try to argue they gave me the wrong ones?
Hey @cjfioren did you have this problem? Can you confirm that part number, or confirm if the screws need to be a different size?I went to install my rear liners today and the 2 screws I bought were too big. The part number is written as 0651 2919 AA but they are obviously different than the existing screws. Anyone else run into the same issue? Or should I just go to the dealer and try to argue they gave me the wrong ones?
If it's the same screw that holds the fender flares on, it's 6510827AA
It is exactly the same ones as the fender flares.If it's the same screw that holds the fender flares on, it's 6510827AA
My truck was delivered missing the wheel well liner screws on the right rear. The dealer didn't have them in stock and had to order. This is what I recieved and installed myself. Problem solved.
Newbie question. Are these liners for the rear wheel wells to cover the coil springs and shocks?
I am wondering how they look? Can someone post pictures with and without? My as build sheet from mopar site shows wheel liners and window sticker does not. I do have some plastic inserts in wheel well but shocks and springs are not covered.Newbie question. Are these liners for the rear wheel wells to cover the coil springs and shocks?
