OEM rear wheel well liners
metb4
Does anyone happen to have the part number for the OEM rear wheel well liners? Thanks!
356
Here is the info from another member.
screenshot_20180918-105753_samsung-internet-jpg.4930
xo151
I went to install my rear liners today and the 2 screws I bought were too big. The part number is written as 0651 2919 AA but they are obviously different than the existing screws. Anyone else run into the same issue? Or should I just go to the dealer and try to argue they gave me the wrong ones?
metb4
I ran into that same issue. I took one of the original screws to the hardware store and found something that was very similar. Not exactly the same but close enough
navnav94
I ran into the same issue as well still waiting to find the correct screws
YoAdrian
Moderator
RI, USA.
Hey @cjfioren did you have this problem? Can you confirm that part number, or confirm if the screws need to be a different size?
xo151
I'll probably do that too.
banditsc
If it's the same screw that holds the fender flares on, it's 6510827AA
xo151
Thanks, I just called the dealer to order these. I'll know by tomorrow if these are the correct ones.
cjfioren
What I did was bring one of the fender screws to the parts dept and told them I need 2 of them. Problem solved.
syddog 2000
My truck was delivered missing the wheel well liner screws on the right rear. The dealer didn't have them in stock and had to order. This is what I recieved and installed myself. Problem solved.
xo151
Picked up a couple 6510827AA today. They don't exactly match the original screws (they are shorter in length), but they work. The person at the counter was going to try to order yet a different part number to match the original I brought in, but I gave the 6510827AA a try instead.
U
User_3336
Guest
6510175AA was confirmed at the correct part (corrected in the youtube video).
RedmanGlenn
Newbie question. Are these liners for the rear wheel wells to cover the coil springs and shocks?
AndreiV
Southern CA
I am wondering how they look? Can someone post pictures with and without? My as build sheet from mopar site shows wheel liners and window sticker does not. I do have some plastic inserts in wheel well but shocks and springs are not covered.
metb4
Definitely looks better with the liners IMHO
