Adding Passive Entry: How-to
Apologies, I thought it was just a problem with the tailgate since you mentioned the rear antenna part numbers. I don't think the rear antenna wouldn't have any effect on the doors since you can just do the doors, that is all done through the RF hub already in the truck and if you choose not to do the tailgate the doors would still work. Just for ****s and giggles though try leaving the rear antenna unplugged and see if the doors work longer than 2-3 times. If they work I guess the rear antenna could be causing some type of interference with the RF hub in the truck maybe. Also you mentioned that when you try to lock it the horn beeps 3 times and the doors unlock. That means the truck thinks the key fob is inside the cab, it's a safety feature so you can't lock the key fob in it. Like the post above, I would double check module settings, it's possible one was missed or the wrong changed in the process. Double check all these settings, on my truck some were already enabled so I didn't need to change them.
PASSIVE ENTRY BCM SETTINGS
VehConfig 3 fobik safe enable- YES
VehConfig 3 passive entry present- YES
LIN and Misc fobik safe alert no reply- YES
LIN and Misc fobik safe alert on system fault- YES
LIN and Misc fobik safe alert on search timeout- YES
LIN and Misc fobik safe alert per ignition cycle counter- 2
Wireless AP1 Left front- SMART SWITCH
Wireless AP2 Right front- SMART SWITCH
CustSetMenu 1 passive entry CSM present- YES
Cust.Prog.Features- Passive Entry Unlock All Doors or Approach Door- ENABLED
Thanks! I double checked the settings above and made sure they were correct. They were correct. Passive entry in on the settings on the Uconnect screen and they are working. The tailgate does not unlock when the handle is touched. And the horn still beeps when the door lock is pressed and the door is closed. I do have the 5th antenna the rear one installed.
Could you clarify something? I just want to push the lock button close the door and they stay locked without beeping and unlocking upon closing the door. And keep passive entry. Am I missing something?? Thanks!!
After reading more all I had to do was change VehConfig 3 fobik safe enable- YES to NO.
I believe by changing the cofig 3 setting you could now lock your key fob in the truck. I think that setting is what prevents that from happening. Again the horn beeps and unlock means the truck thinks the key fob is inside the vehicle, that is one of the settings that should have already been set to yes when you first started. This might sound stupid to ask but I've seen worse, do you by any chance have another key fob inside the truck? maybe in the center console, under the seat or something like that? It's acting like it's sensing a key fob inside the truck. As for the tailgate it wont unlock just by touching the handle, you have to actually push the release button like you normally would to open it and it should unlock and open simultaneously. beyond this I'm sorry, I may not be able to offer anything else to help when I installed on my truck everything went smooth and it has worked without issue.
I used to spend hours or days reading through these threads. I was able to get Microsoft CoPilot to summarize the entire thread, including special notes for my 22 Ram 1500 now I’m ready for the install.
Genuine Mopar Passive Entry Switch 68403083AA
I am looking to do this install. I found this in my searching for parts. Does anyone know if this is the part for the door handle. I can't get a good answer.
Does the passive entry not work when the truck is remote started? Is there anything I can do to change it to where it does work during remote started.
What do you mean? When it is started, you just walk up and touch the door handle and it unlocks. But you need to have your FOB close by.
That’s what I’d assume- but when it is running after being remote started - the passive entry does not function. One I click the start button. It all works normally again.
That's not how it is supposed to work. Did you add it yourself?
Thanks for asking about the extra key fob. One is in my pocket, the other is in my wife's purse in the house. Before I had PE, I could lock the truck's door with the key fob in my pocket, close the door, and it would lock and stay that way. I just wanted to get back to this function with PE. Now it works that way.
Alright, so Indid this awhile ago and it has been perfect. Until recently. It takes 2 presses on the drivers door to lock it. The first one rarely registers.
I was going to swap them but the t25 in the door that holds the cap on just spins. It doesn’t loosen or tighten anything.
Did I break it?
Is there a way to replace this mechanism?
I found the part and its connected to the inner door shell. Now to figure out how to get the cap off.
If I remember correctly, the cap screw does not come out. You just loosen it while applying outward pressure on the cap until it comes off. The screw just loosens the clamp and stays inside the door. It’s been a while since I did mine so I could be wrong but I think that’s how it works
right, it doesnt. But i think mines messed up because it just spins. Doesnt seem to be loosening the cap at all. The plastic frame that holds it includes the mechanism that holds it in place that is connected directly to that inner shell. So if i can figutenout how to remove the spinning torx, i can replace the whole piece.
Yeah sorry about that. Not sure what to do about it
I’m trying to weigh to pros and cons of removing the door carrier plate versus routing the two wires as explained in the Infotainment video. Not trying to cut corners, but there are obvious risks to fully disassembling the door carrier plate.
I appreciate comments from those that have completed this modification using either approach.
Thank you!
Thank you!
I removed the carrier plate when I did mine. It guarantees the window won't hit the wire because it runs on the inside with the main harness. There's a reason the main harness is on the inside to avoid any issues. It's not that much work to support the glass and remove the carrier in my opinion. Just my 2 cents.
