Rubber mud flaps vs splash guards for Rebel
RAMDJ
How many of you have found full rubber mud flaps for the Ram Rebel? I think the look of rubber flaps would look great on the rebel but after a few quick google searches, I wasn't able to find any that I liked. Does anyone know of somewhere I can get easy to install custom flaps.
Second, what is everyones thoughts on the splash guards. Does any one have a profile picture of their rebel with the splash guards? They seem to be very inexpensive at $50 per two. Also, with he rebel package, do you get the ones with the fender flares or without?
Gatorback mudflaps is what you want. Full rubber with a steel plate for durability.
I am looking for something I don't have to drill and are ready to go. I did find https://duraflap.com. Not sure if anyone has an experience with this company.
Its one hole per flap takes 5 seconds. And it’s through the plastic inner fender. I had all four of mine on in 30 -40 min
the Mopar Ones fit awesome, and are very nice to install. see my profile pic
do you have the full rear wheel liner or just the two partials ?
The Husky will not fit the partials
I installed these Gatorbacks on mine: https://5thgenrams.com/community/threads/gatorback-mud-flaps-w-pics.4727/
Link with pictures.
I do like those gatorbacks. My question is do they come pre-drilled with the screw holes? Also what size works best for the front vs back.
I have the full wheel liners as the truck has 4-corner air suspension.
I did not install the Gators...had dealership do it b/c I did not have a drill that could fit in the space between the tire and quarter panels. I need to get a right angle drill eventually.
But there are 3-4 holes in each flap and an extra that you have to drill through plastic I believe, and not the metal.
Another item of importance is when you lower the truck to Enter/Exit via air suspension those flaps are about an inch or 2 off the ground.
Are you supposed to get the ones with the fender flares or the non fender flares with the Rebel?
Yedi I went to the mopar site and i don't see the side steps you have. I like those. Could you provide a parts number or website
Can the mopar flaps be painted? Do they collect water/dirt in the pockets? I love the gatorback but pricey.
Rough Country Wheel to Wheel Nerf Steps for 2019 Ram 1500 Crew Cab | 5' 7" Bed https://www.amazon.com/dp/B07DWFBSHF/ref=cm_sw_r_cp_apap_DFFnKSQO6p5B4
Awesome steps, lifetime warranty also. Bolt right up to factory studs. These are heavy duty!
Yedi, I'm still on the fence with those or these. https://www.realtruck.com/ici-black-magnum-rt-steps/R184321P2019Y2712MA.html
both look great and are about the same price. So you didn't have an issue with the splash guards hitting the steps?
I just got mine in today. Did you do the drilling on the bottom or just leave it as is with the screws?
Also, does anyone know what this is?
I am assuming it is a rivet tool.
that's a plastic rivet gun. I didn't drill any holes, just used the factory locations and screws. they aren't going anywhere :-)
that's a plastic rivet gun. I didn't drill any holes, just used the factory locations and screws. they aren't going anywhere :)
I was assuming it was the rivet tool. And you left the rivets out all together? I was debating on just leaving those out as the bottom rivet is what they want you to drill according to the instructions.
