Congrats on the new car! I know exactly how that feels — my wife and I both have Challengers too, so I definitely understand the excitement. That’s a great-looking ride, and I’m really happy for you. Enjoy it, and make a lot of good memories with it! 😎🔥View attachment 214342
Did a first road trip (after 5 hrs drive getting it) on Day 2..and Wifey-pooh likes this one better than she liked the '15 SRT392..so off to a great start! Thanks again👍
BTW..nice looking group you've got there!
Yesterday went on a poker run with a group of Jeeps, and a couple Broncos. Was a benefit for a family going through cancer treatments. circled my truck in green in the ribbon picture. And that black dot in front of my truck, in that picture, is me.
Changed the oil and did a look over on how things were looking under the hood. At 64k miles and looks like I am one of the lucky ones with oil in the coolant. Found residue on the coolant dipstick and I used medical tape attached to the coolant dipstick since it was low and couldn’t tell the level and the coolant fluid color was like a caffe latte. Made an appt with the dealer this week since I have an extended warranty.
I’ve sent my oil off to black stone labs and there has never been coolant in the oil and my oil when I changed it yesterday looked normal with no milky discoloration.
Guess now I wait and see what the diagnosis is.
Oil pressure is higher than coolant pressure which is why you don't have coolant in your oil.
Identified the exhaust leak I’ve been hearing since the arctic cold settled in this Winter
Thought I would drill and bolt this tomorrow, but it just hit me that I’ll need a gasket. For now I’ll put a c-clamp on there to keep it all together and quiet until I get a gasket.
Got a chance this morning to work on this exhaust issue. Took a while to get that broken bolt out, I had to heat that sucker up as much as I could with a little propane torch, but it came out. Then I realized the two and three-quarter inch gasket that I bought is too small since this is a 3 inch pipe. I was able to clean the old gasket off with a die grinder and reuse it, I’ll get a new one coming but for now it’s good. While I was in there I realized it was time to change the oil so I got that done, dumped about two or 3 ounces out of the catch can, oil did not look bad at all in there.
Took it for a test drive after I change the oil as I always do, this time I pulled over in a park and felt I needed to do a throttle calibration right there. When I got back out on the road the battery light came on and the indicator showed it was charging at 11.6 V. I wasn’t that far from home so I drove home and shut it off, checked it out in the driveway, everything looked good. Shut it off and started it up a couple of times, the second time the voltage was back up to 14. Took her for a drive and everything seems good, so I think at exactly 4 years it’s probably time to start looking for a battery.
If you were trying to make me jealous it worked 🤪
Added the VTT dual catch can & one way breather to my Hurricane. Plug & go, pretty clean & simple!
New TRX hat count? 😵‍💫 came home from hospital with no shoes or hat
I feel weird about buying a hat that doesn't belong with my truck but I can dream... 🤪
In case you were wondering, you may NOT borrow my truck…
It was in great shape for 7 years until I started hauling firewood every weekend
DO THE HOSES REALLY HAVE TO BE RAN OVER THE BATTERY, KIND OF AN EYE SORE.
I think that’s the fuse box but the photos from their website show them routing more toward the engine and down lower out of the way so I would imagine these photos were taken before he “tidied up”. I would hope at least.
Forgot to post when I installed it a couple weeks back.
Ordered the "Morimoto 2019+ Ram 1500 X3B LED Third Brake Light". Very easy installation. As plug and play as you can get. I like the strobe effect. Anything to get people's attention, I'm all for.
TLDR: Shaggy dog story incoming. :D
Technically speaking I didn't do anything to my truck today, besides driving it, but I did do something else ...
Two days ago I noticed that my headrest wasn't set fully back, must have been like it about a week because, despite finding the seating arrangement quite comfy, I have had screaming backache for at least a week. So I did reset the headrest, but that was two days ago.
Thanks to a number of things my L3/L4 is mullered - 60' leader fall climbing, 12' fall solo ice climbing (landed perfectly but let go the axes in order to do so, my adze came up hard on it's leash and planted itself firmly in said spinal joint, ouch. Getting trashed in kayaks in big storm surf and running grade IV rivers, multiple motorcycle accidents including getting t-boned by an idiot (not me, this time) running a red, getting caught in a 'movement of some big material' while exploring a disused mine probably hasn't helped the back!!!
On top of that a delightful arthritic condition called Ankylosing Spondylitis (try saying that after 8 pints!) gives me grief further up around the C3, my chiro has done a pretty stellar job getting rid of the old hunchback, and yes Quasimodo springs to mind but I'm not as pretty as Charles Laughton's character. :ROFLMAO:
So, summarizing so far, both my lower and upper back have been screaming thanks to a headrest too far forward, doesn't help that I've got real short legs and a nice long back, what with that and the stupidly wide shoulders with long arms those that have ventured in calling me a knuckle-dragger haven't been too far off the mark! And that C3/C4 joint is deteriorated enough that when it plays up I get permanent pins and needles in my right arm.
Anyhows, back on topic, :ROFLMAO:, thanks to a wrecked right Achilles Tendon, 'luckily' it's probably only tendonitis, unlike the left one that I snapped 12 years ago, I have taken to dipping my feet in the tub when my wife takes a bath. Today I thought stuff it, things can't get much more uncomfortable, so after at least 200,000 mile of motoring since the last one, I took a bath. :ROFLMAO:
