Cleaning method between cab and bed
Danthecarguy247
IMG_0821.jpegHas anyone come up with an effective method or easy hack to clean the gap down low between the cab and the bed? My truck is loaded with leaves and other tree debris (pictured) and blower/water hose are ineffective.
Yep, I don't miss the helicopters. We've got other issues in the desert, but thankfully helicopters aren't one of them.
This is a problem? Wasn't even aware this was thing, now I feel like I need to check my truck
LOL yes don't look. What problem? Did once have to water jet some crud out, got to it from underneath. But that all started because for some reason I looked. Should not have done that.
Of course you know I had to look. Other than a couple pine needles, I don't see anything that bothers me. Might be because I go to a touchless wash weekly that has a good chassis wash as well, so water under pressure from below as well as sides and above.
I very carefully used a metal drywall t square to clean it out, not an area anyone will see but can only imagine the potential for rust/damage with that stuff sitting in there.
