I need it with some kind of gun clip
With some sort of backing plate, you should be able to mount a RAM mount ball to it. Then you can add a gun mount to that.
I'm in the same boat now. Two attempts by Fibernew at repair. First ones the patch peeled off after a few months. Waiting to see how long the latest repair holds up. Fibernew tech said to call warranty company each time so need seat repaired. And they will push back recommending new seat covers based on have to redo repairsI had mine repaired by Fibrenew Vinyl repair. It lasted a while but didn’t stand up. I ended up having the bottom cover replaced with OEM one. My dealership did it…gratis.
haiya spilling my secretsWith some sort of backing plate, you should be able to mount a RAM mount ball to it. Then you can add a gun mount to that.
What brand of wheel house liners did you chose??Technically I didn't do all of this today, but I have had a productive week of things. I installed a new X2 Power H7 AGM battery. Installed rear wheel well liners, and got a dent in my tailgate fixed!
ay, View attachment 212676View attachment 212677View attachment 212678View attachment 212680
I used these and they were very easy to install even with the wheels still on.What brand of wheel house liners did you chose??
Something to consider next time you do an lof: I drape a large puppy pad over the rack, and just let all of that oil run right down into my drain pan. After the filter is on, I spray a little brake cleaner around the housing to clear off any residual, then slide the pad out and toss it.Thankfully being a slight hoarder came in handy lol. Saturday I was headed to town and noticed my brakes felt really odd. A few moments later I get the ABS light and traction control light. Made it home and scanned my codes - had an oem code of
Code C0031-2F which indicates an "Left Front Wheel Speed Sensor Signal Erratic" fault. Parked the truck and this is where hoarding comes in handy. I'd bought two front wheel bearing hub assemblies but never replaced the driver side. They come with the speed sensor pre installed. So I was able to use that while I wait for it's replacement to come in the mail. Unfortunately I believe my driver side wheel bearing is shot. The speed sensor had some metal shavings on it and the face had a groove being warn into it. So it looks like that'll be my project over vacation in a few weeks.
Also changed my oil the day before I did the speed sensor. This will be my third run of Restore and Protect. I don't know what I was doing wrong but I made a mess everywhere lol. Normally I can do the two bag method with minimal spillage. This time though I finally just said screw it and let oil go everywhere. Everything felt off. Couldn't get my oil filter in. Hand and arm placement felt weird. Was just a very weird experience lol.
sometimes it's like that.Thankfully being a slight hoarder came in handy lol. Saturday I was headed to town and noticed my brakes felt really odd. A few moments later I get the ABS light and traction control light. Made it home and scanned my codes - had an oem code of
now im looking up puppy pad. will come in handy for sure!Something to consider next time you do an lof: I drape a large puppy pad over the rack, and just let all of that oil run right down into my drain pan. After the filter is on, I spray a little brake cleaner around the housing to clear off any residual, then slide the pad out and toss it.
I’m not sure what size I am using, I think they’re about 18 to 24 in.²now im looking up puppy pad. will come in handy for sure!
what size is good?
You use a puppy pad to drape over the oil filter area when removing the oil filter during an oil change?Something to consider next time you do an lof: I drape a large puppy pad over the rack, and just let all of that oil run right down into my drain pan. After the filter is on, I spray a little brake cleaner around the housing to clear off any residual, then slide the pad out and toss it.
Over the crossmember/rack, below the oil filter. Whatever oil does not get soaked into the pad drains down the hanging pad and into the drain pan.You use a puppy pad to drape over the oil filter area when removing the oil filter during an oil change?
2025 RAM 1500 Hurricane HO Limited
I have recently succeeded in viewing my trailer camera through the digital rear view mirror via the coax plug on the rear bumper.
I absolutely love being able to see the road and traffic behind me through the OEM mirror.
Thank you for the description!Over the crossmember/rack, below the oil filter. Whatever oil does not get soaked into the pad drains down the hanging pad and into the drain pan.
