AlfaOBD Known Changes 5th Gen
I made both changes...
Horn Beeps D/C worked.
Front Cameras with Sensors didn't seem to work.
Strangely, my screen shot of last Google Drive Files shows "NO" but when I went into CCC then CSM3, then PS Based CA..it showed "YES" and says "No Changes Necessary" (or something like that).
When I start the truck and put in Drive, the yellow sensor line and Beeps come on, but no camera unless I manually dangle it on.
Did I miss something or not possible? Thanks!20260217_083152.jpg20260217_101203.jpg
You need to wait for the setting to show up in the radio so you can toggle it on. It’ll be under cameras or safety driving assistance.
You can force it to show up right away by rebooting the radio twice in a row- press and hold the power button for about 15 seconds until it restarts.
I was just wondering if I might have to do that..THANKS for all your help, I super appreciate it😁
Sure enough..there it is..works great!
AlfaOBD..with your help..is really amazing!
Again, thanks Jimmy👍
Sure wish my 19’ Limited could do that. I turn the front camera on manually on the radio screen at the moment.
Yep, that was me before Jimmy07 showed me the AlfaOBD programming..I love this!
They are two completely different things. If you want the camera with park sense on your truck, it's the only way. And TazerDT also acts as a SGW bypass for alfaObd
Except..I did the Front Camera with Park Sense, and it works perfectly.
So hard to keep track of who has what model year. Using mobile version of the forum it hides the signatures .
I always wondered why I lost the ability to see Signatures (idk, maybe a year ago?)..I thought everyone lost them since I can't see anyone's Signature/Info anymore (I have to go into the Avatars to see info.🤔
I have all the required AlphaOBD and equipment and used it for other adjustments. I don’t believe you can do the front camera on with sensors. Maybe @Jimmy07 could comment.
My 2024 was able to do it with the above AlfaOBD CSM3 change Jimmy linked me..your 2019 may be different, but maybe Jimmy has an option for you. I really love it.
As long as you have show people’s signatures checked in your preferences, you just rotate your phone to landscape mode to see people’s signatures.
They did this because some people write novels for their signatures, and you had to scroll forever to get from one post to the next.
I hardly ever rotate my phone unless I'm watching a video. I would have never figured that out. Just tried it and it does work, but I'm not going to surf the forum in landscape mode. So will continue to just be confused, or ask.
Son of a gun, it does work!
Faster than clicking on an Avatar & checking for info.
And once again...THANKS JIMMY!
I mean, you only need to rotate it the moment before you assume, or don’t know, what vehicle someone has…
