bed covers
chief2020
I have a 2025 Ram 1500 and want to add a cover probably a hard retractable cover like a Retrax brand. Anyone have any recommendations for brands or experience. I have the RAM tie down bars in the bed. Is that going to be a problem installing one of these covers? My brother-in-law has a Ford F250 with the Retrax and is very happy with that brand.
When you say Ram tie down bars are you talking about the utility rails? There are two versions that come with 5th gens, black and silver. There is a difference in them and will make a difference in which bed covers will work for you. Most covers work with the silver rails. Which do you have in your truck? Also, does your truck have the rambox option or MFT (Multi Function Tailgate)?
I have the Warlock version and it has the bed rails inside the bed with adjustable hooks. No Rambox or MFT. BTW, you truck looks awesome.
Sorry, didn't mean to ghost you. This thread dropped off my radar. Thanks for the truck compliment! Not sure if you've bought a cover or not yet.
Going back to the bed rails, both the black and silver rails have adjustable hooks. But they are not the same. Pics below show examples of each rail type:
Silver rails
Black rails
Usually, you get the black rails if the truck came with the factory bed cover. You get the silver rails if you get the Bed Utility Group and no bed cover.
Since you're wanting to add a bed cover I'm going to assume your truck did not have the factory cover and you have silver rails. Just know that when shopping for a cover you need to know which utility rails you have.
I have the BAKFlip G2 cover and it works great for our needs. They make several different covers so you may want to check out their covers.
Can someone explain the physical differences in the two rails (silver vs black).
TIA
I have this, a little pricy but good quality.
TIA
They both mount with the same mounting holes but the black rails sit higher in the bed IIRC. I believe the top is also different, but it’s been five years since I’ve even seen a set of black rails.
My previous trucklet had a retractable cover which worked really well, but, I didn't like how much of the bed it took up so I removed the whole thing for the non-winter months, when I used the bed more. On this truck I opted for a soft tonneau cover for that reason.
If you need the space then that's a consideration, and I think there are retractable brands which can easily be removed (with two people).
I have the black rails with the factory tonneau cover and Ramboxes. Looking to confirm I need to swap to the silver ones to install an MX4 and also would like to understand why.
I believe the silver ones sit a bit lower as compared to the bed rail but no explained thus explicitly.
I’m running into the same issue I have the black rails with ram box. Do I need to purchase the silver rails to make a roll up cover work?
I am running into the same issue - I have the soft tri-fold tonneau on my new 2026 Limited with Ram Boxes. It came with the black rails. From my research, I can now see why the silver rails are needed to mount the MX4 (and others).
This pic came from an ad for a tonneau and shows the profile difference of the black vs silver rails:
I grabbed these screen shots from this install video from Youtube.
You can see the silver rails in the truck.
The top rail of the MX4 slides into the channel on the silver rail (where his finger is pointting):
You can see below the top black section of the MX4 being slid into the channel on top of the silver rail. This does not exist on the black rails.
The OE silver rails support the installation of an aftermarket tonneau cover. The way that the tonneau rails and clamps are designed make installation more manageable with the OE silver rails.
Feel free to DM me or email me if you have questions about fitment, installation or pricing!
