AlfaOBD Known Changes 5th Gen
Okay, so in the first post here is discribed, how to setup accent lights as DRL:
CBC Features DRL Configuration- OPTIONAL
CBC Features DRL Lamp Location- DEDICATED
CBC Features DRL Dropout Enabled- YES
CBC Extern.Light Calib. Signature Light Present- NO
CBC Extern.Light Calib. Left Side (and right side) DRL Voltage Target- 7.4 (but can be raised)
CustSetMenu 1 daytime running lights CSM Present- YES
For sure, that this won't work? I'm confused - sorry...
Hello everyone,
Thanks for your help!
I tried to put the DRL in the fog lights and failed miserably. I don't have an option to activate the daytime running lights in my uConnect either.
My country code is set to Kazakhstan, as with all “export RAMs.”
However, I activated the display in AlfaOBD, set the DRL to “Optional DRL,” and then set the lamps for the DRL to fog lights.
Unfortunately, without success... Can you tell me exactly which options I need to set?
Thanks in advance!
The option for fog lights as DRL does not work on the 5th gens . It's nothing you did wrong, it just doesn't work.
Does not work, never has.
Can someone help me to reprogram the milage on my updated limited dash speedometer cluster cut get it to take the milage correctly any help would be appreciated can pay for the programming im in NJ
Thank you it worked great that was my problem was entering it in miles would have never figured it out as it was so much less, thanks again for the fast nd accurate response
Alfaobd can do the mileage on the analog clusters. Make sure to enter the mileage number as the kilometer equivalent to what your mileage is.
WHAT? You can change your mileage? Is that legal?
Of course it’s legal. How else would you correct the mileage when your instrument cluster fails, and you need to replace it with a new/used one?
The only thing that’s illegal is misrepresenting the mileage when you sell a vehicle (and trying to commit warranty fraud). Otherwise, you can set it to whatever you want when you own the vehicle.
We've been over this many times.
This is the correct answer that is provided every time.
Thanks. I knew mileage could be changed, I just didn’t realize you could do it personally with AlphaOBD. I thought it had to be done by a dealership or some other regulated authority.
So.... I've been monitoring this thread for several months and have seen no updates; are the AlfaOBD folks getting anywhere with the 2025+ Rams? I've got a couple things driving me absolutely insane (comfort temp, 3 horn blows when keys leave the truck, etc.) that I'd love to correct.
Any information available?
I did. not change the milage I input it mile for mile I have kept all records of service and oil changes at dealership, no funny business I love my truck just needed a little interior update and the limited speedometer was what I chose without going digital which I dont like, on a side not I did not have to change the badge from limited to Laramie after a few cycles it changed on its on big. surprise and very much welcomed looks amazing, thank to Jimmy for all his help
Question, enabled tailgate ajar, where is the light or indicator gonna be ? Will only show when running in park or ?
