KINGFUROOK
- Jan 28, 2025
Amazon.comWhat lights are those?
My post should have (edited to add) specified the trailer alerts pertain to 25-26MY. Pre-25MY don't have issues with trailer harness taps.Guess it all depends on what harness you use, or what wires you tap into. No issues on my 2020 using the Vice Design trailer harness adapter.
i honestly didn't know you were getting the Carli springs or else you could've just got my old Carli Rebel HD pair for way less hahahaThis weekend, I completed the Rear suspension. I went ahead and installed the Rear Coils from Carli and the Bilsteins 8100.
First time ever doing this type of work, but if I could do the Long Tube Headers myself I could do this haha.
Had some hiccups when lowering the diff, you have to be careful with brake lines, and for some reason my driver side would not drop enough to remove the old coil. I did have 2 inch spacer, but the passenger side came off fairly easy.
Rear feels like BUTTER! Can't wait to do the front 8112s with the Dirt Kings UCAs.
Unfortunately I have to wait for one 8112 that is on Backorder. They said 3 weeks, can't wait to try them on the whoops!
By the way, I did not add back the plastic liners (last pic) I think it looks way better, more offroad like.
oh I def would've gotten them from you haha, I went with regular Rebel because I don't usually carry a lot of weight. I think I calculated like 100 lbs when I go out and maybe less.i honestly didn't know you were getting the Carli springs or else you could've just got my old Carli Rebel HD pair for way less hahaha
i changed them because of the weight.oh I def would've gotten them from you haha, I went with regular Rebel because I don't usually carry a lot of weight. I think I calculated like 100 lbs when I go out and maybe less.
Why did you change them? Was it for a heavier loaded coil? I know you carry a ton of weight.
Looked at my Patriot Blue Limited and thought "I wish it wasn't 5 degrees outside because it really needs a bath.
im having the same issueView attachment 211893
Finished ambient Light installation. Satisfied with result.Started ambient light installation.
How? And how much? That looks amazing.Finished ambient Light installation. Satisfied with result.
Post a parts list and how you did it. It looks good.Finished ambient Light installation. Satisfied with result.
I ordered two sets (about 40€ each) because one kit wasn’t enough length for the amount of strips I wanted to run. Total cost: ~80€. Check out pictures in attachment.Post a parts list and how you did it. It looks good.
Well done. Can we see close up pics of the strips installed both turned on and off? I'm curious how they look in the daytime when you can't see the light.I
What I installed (layout)
I used the strips like this:
So overall it ends up looking very “factory+” and fills the cabin evenly.
- Front dashboard / front panel: 3 LED strips
- Center console: 2 LED strips
- Doors: 1 LED strip per door
- Plus extra lighting for:
- door handles
- footwells / footsteps
- door pockets / door area
Honestly the quality is good for the money — strips are bright, effects are smooth, and the interior looks way more premium at night. For ~80€ total, I’m really happy with it.
- Day 1: ~4 hours
- Day 2: ~3 hours
Total: ~7 hours DIY- App control + remote control
- About 200 presets (lots of animated / “streamer” effects)
- Zone control (front + doors separately)
- Brightness + speed adjustments
- Music mode is included too
