Zztopman
- Oct 26, 2025
What is even known as a proper reboot?Make all the changes, then do a reboot
Then just turn off ignition and walk away for 5-10 minutes before restartingWhat is even known as a proper reboot?
Global windows doesn't work on 5th gens. But you can buy a TazerDT and it gives you that feature.My main focus for entering the AlfaOBD world was to enable the OEM trailer brake controller that I installed. Dealers wanted $950 and $1050 for the entire job and one wanted $310 just for programming. I did it all for $450 YAY!
I attempted to enable 3 other features.
Fog lights stay on with high beams = successful.
Global Windows down/up = failed.
4 lever heated steering wheel = failed.
Thanks for the info.Global windows doesn't work on 5th gens. But you can buy a TazerDT and it gives you that feature.
Hesterd steering wheel, I had line set to 3 level, and it worked for a while. Then i updated the Uconnect app version and lost that and tailgate ajar indication.
Global windows aren't worth the cost of the Tazer. I just thought it would be neat to have even though I can't think of a personal use for it.
No, you don't lose anything. You would lose something if you updated the BCM. But those changes aren't going to affect your streaming.Since turning on the OEM trailer brake controller, fogs on with high beams and multi temp heated steering wheel, my streaming music from YouTube and using Android Auto, skips.
I tried unpairing & repairing and soft restart of head unit.
Will I lose any of the AlfaOBD settings that I changed if I reset the head unit at whatever the next level reset?
the advantage of having the dealer program it is, it will then be on your build sheet in case you ever have to reprogram the computer.My main focus for entering the AlfaOBD world was to enable the OEM trailer brake controller that I installed. Dealers wanted $950 and $1050 for the entire job and one wanted $310 just for programming. I did it all for $450 YAY!
4 lever heated steering wheel = maybe worked. Hard to tell since the icon does not change, but there are 3 on presses before the icon shifts to off.
Pure coincidence that the music started skipping after your changes. Nothing you changed wound effect that, and the changes you made were to the BCM, not the Uconnect display.Since turning on the OEM trailer brake controller, fogs on with high beams and multi temp heated steering wheel, my streaming music from YouTube and using Android Auto, skips.
So, I can go nuts resetting everything until it fixes it with no fear of losing changes to the BCM. CHECK.Pure coincidence that the music started skipping after your changes. Nothing you changed wound effect that, and the changes you made were to the BCM, not the Uconnect display.
Correct.So, I can go nuts resetting everything until it fixes it with no fear of losing changes to the BCM. CHECK.
Thanks!
Those aren't your DRL those are what Ram calls "signature lighting". There should be an option on your display menu to toggle DRL on/off, which will be your headlight low beams.Hello everyone,
I have a 2020 RAM 1500 Limited.
My DRL is in the headlight "eyebrows", which is how the car was delivered. But I find it relatively dim.
What values do I need to increase with AlfaOBD (and what is the maximum setting) to make it brighter?
Thanks in advance and best regards from googd old Germany!
Florian
Ahhh, okay - so is it possible to increase the brightness of this signature lights as I asked? (max. voltage,...)Those aren't your DRL those are what Ram calls "signature lighting". There should be an option on your display menu to toggle DRL on/off, which will be your headlight low beams.
No, unfortunately you can't increase the brightness with alfaObd. There has to be some way, because when you remote start the truck, they are brighter than when driving. But there isn't a setting that anyone has found to change it.Ahhh, okay - so is it possible to increase the brightness of this signature lights as I asked? (max. voltage,...)
TazerDT will allow you to change what bulbs are used for DRL but won't change brightnessOkay, thanks a lot!
So I will check if my Tazer DT has a possibility. Perhaps live functions![]()
Definitely need a cheat sheet for all of those choices!Unfortunately, without success... Can you tell me exactly which options I need to set?
Thanks in advance!
