Transmission fluid change - Pan??
Glenn54
Deep East Texas
I have about 56,000 on my truck. Some of these miles are with towing and some at higher speed, 75+. I know the stock pan has a filter built in but is there a pan made that has a seperate filter, so it can be changed without a new pan? If you know which pan it is, please provide part number. Also, if you have changed the pan and fluid yourself, was it difficult? Getting a little old but can still change the oil when I want to. Thanks.
try this
Ive serviced my Durango with 8HP70 several times. The only trans pan with a separate filter Im aware of are a Dorman (265850) and a Autotecnica brand. After seeing the Dorman in person and knowing the reputation of the parts they make, I wasnt putting that in my vehicle. I bit the bullet and got a real Mopar pan online. After changing the pan with filter at 50k, I decided to just do drain and fills every 25k until I reach 100k. Its an easy job overall. Id recommend finding the process on youtube before you start the job just to familiarize yourself.
I am looking to change my transmission filter as well and understand that the pan and filter are one part, yet when I go to purchase the pan I see they sell the filter separately. How so if they are one piece? Also I see another filter in the schematic that looks like the screw on type. What parts do I actually need if using Mopar parts aside from the fluid? Part numbers would be appreciated if possible. 3154.jpg
Rock auto must have their stuff messed up then. I will look into it. Thank you.
Might want to watch few videos on You tube about changing the pan and fluid.
Blauparts... has a pretty decent one IIRC.
Here.
Not worth it to replace with another plastic pan. If you’re gonna spend that much money may as well get an aluminum one that you can change the filter later.
What do you recommend that clears the cross over pipe ?
I might go that route after my next trans. service.
Don’t have a specific one. Are you saying you can’t find one that fits? I’ve found them with a quick search that says they are for the hurricane engine. So without test fitting one I would have to assume they fit just fine. Have you experienced otherwise.
There have been some post discussing the subject matter. Some had found out that all of them do not clear the cross over exhaust with the 5.7 hemi.
part number 228053000
Dorman 265-850 Transmission Pan With Drain Plug, Gasket And Bolts Compatible with Select Models (OE FIX)​
While it’s not a particularly hard job, you’ll probably be glad it’s finished. You may end up with some exhaust burns along the way. I was able to complete it by lifting the back end of the tranny in lieu of disengaging the Y-pipe but I’ll probably do it differently next time. A perfect time to do it would be if and when you change your exhaust manifolds or convert to shorties. Nothings ever easy. Especially when you have an outdoor garage on a hillside. Lol. But, Amsoil ATF seems to add a little kick to my drivetrain. These trucks are crazy fast. Addictive!
Oh the 5.7. Ya I’ve found some that say they work with the hurricane. Wasn’t looking for Hemi. lol
