How's your truck holding up in this cold?
Neil McCauley
AM starts are just a little rough, fluids are all <0*F.
One of my TPMS sensors is throwing an error but starts working again after ~30 mins driving.
Leaving a fob in the truck overnight is a mistake. Won't even start holding it against the start button. Have to warm it in your armpit for 5 mins.
Power running boards...forget it.
Other than that doing OK.
No issues whatsoever.
It sat Saturday through Wednesday covered in sleet and ice. Started right up and drove to the gym
Mine spends it's nights in a heated garage so no issues in morning. Afternoons I have been using remote start through the app and it's always running when I get there. I do think I have another cracked exhaust manifold. But that will wait for warmer weather to diagnose.
Also when it's below 0 outside I get a clunk that sounds like it's coming from the front . Happens when you get on the gas, and let off quickly. I can make it happen at most speeds but the faster I'm driving the less noticeable it is. I've climbed underneath in my garage and could find anything loose on front suspension, drive shafts, or exhaust.
No issues. Although we are having record highs, I took it out in the morning when it was still in the 50's.
No issues other than the MFT tailgate won’t lower. Barn door opening is fine. Maybe not a cold problem though. Less than 500 miles on the vehicle. Fuses are fine and I can hear an electronic sound when I actuate the release handle but cannot hear anything at the handle itself. Having a tailgate that cannot open without an electric actuator is beyond bonkers to me. But, on a positive note, the truck fires right up in -10F without any problems. No air bag issues to speak of either. Knock on wood
When it’s in the teens, I get a pulley whine for about 2-3 secs then gone. And the driver side exhaust manifold has cracked. I’m blaming the damn cold lol.
I feel like I heard a little manifold noise after work, the day it was -10. Haven’t heard it since tho, not sure what it was.
My truck, as noted below just, under 72k miles. The temps here in the Richmond area for the last several weeks have been mostly under 32 F high and lows in the low single digits several days, low teens several days. Several days the truck has not been driven due to driving another car. I have, also done the H8 battery swap about a year ago. It has started as expected. My truck lives outside 24/7/365, and I keep all car remotes in the house as well.
It is a known fact that cold/heat/age kills the battery in modern cars/trucks; the expected life is 2-3 years, your mileage will vary.
Bluehemi1500
In the single digits it makes some new noises, but all my vehicles have done that. I have a 21 Rebel with the original battery, and it had no problems cranking even at 0 degrees. Everything ran fine.
No issues at all. Well, except my windshield washer fluid nozzles freezing for a little until she heats up
No issues. When we had morning temps of -33, I hit autostart from my bedroom window and it fires right up. I guess the only thing that happens is sometimes moisture freezes between the bed cover and the tailgate and I use a plastic trim tool to break lose when needed.
service tire pressure system or something like that. the sensors are 7 years old so i just assume the need to be replaced
Not too bad, but had 2 days where my fuel (Diesel) gelled slightly. Had two long cranks with only coughing but no start. Temps hit about -10 Fahrenheit the one night. 5 minutes with the block heater plugged in solved that issue, and I've upped my dose of anti-gel to compensate for future problems. My normal fuel station doesn't sell treated diesel :(. Most frustrating part is all the fuel at my job is treated, but its the cherry flavored stuff.
Had a series of 10 degree days, and zero windchill days, never an issue.
My 3.6 split the oil cooler in November. Per the dealer they are getting a lot of them due to the cold. In BR Wed and out by Fri.
I would like to have replaced with the all metal one from Dorman.
