USB media drive suddenly not working
CSPCRX
I have a usb thumb drive with about 2200 songs on and it’s been in the truck for about a year now working just fine. The other day I jumped into the truck and discovered it only shows two songs on the drive. Anyone else seen this. Not sure what could have changed to suddenly cause this, system update? Anyone else seen this?
If you plug the drive into a computer are the files still there? The thumb drive may be going bad.
Oh. I'm sure he checked for that before posting.
I'll bet he also tried a different thumb drive to see if that worked.
You know; common sense stuff.
We'll probably never know....
Steve
Sorry for not including those details. Files are all there and work on my PC. Don’t have another drive the same size but doesn’t seem to like any drive. Also tried the USB next to it and no difference. Didn't know if some update went out over the last week and created an issue.
Good to know the files are still there. The last update my truck received was back in May so nothing new that I know of.
You could try putting some files on a different drive even if they all won’t fit and see if that works. If it does you could copy everything off the drive format it and put the files back to see if there’s just something weird that happened to the formatting on the drive.
Other than that I don’t have any good suggestions. I haven’t played music from a storage device in a very long time.
I've had my 22 w/ 12" screen eat 2 usb thumb drives. Mine tend to last about 2-3 months and then nothing. Unfortunately, both were scorched earth and not salvageable.
For reference: the drives I tried that failed on my gear were the Sandisk micro platform USB-A thumb drive.
Interesting. In your case could you still see and access the files on a PC or was the drill totally cooked?
CSPCRX, it was scorched earth I had thought. Tried it on multiple devices and it would either freeze the device, throw a drive error, or just sit there and do nothing. So, if the drive is toast, I got nothing to loose right?
Pulled out a EaseUS Partition Master disk partition/recovery tool.
Performed a wipe on the drive.
Reformatted back to FAT32.
Drive recognizable now!
Loaded some jams.
Currently jamming. :)
So yeah, drive was corrupted. I still say a drive overheat condition was the main cause. I just leave it plugged it and even the identical type drive gets pretty warm. So yeah, we're back in business.
Appreciate the insights will have to give it a try.
Not saying it's gonna be a 100% fix, but it did work on mine previously and as of today, has worked for several coworkers as well. Hope it works for you!
I wonder... considering doing this with one of the several USB drives I have sitting around too slow for most any other use. Can you use the port in the center console of a 2025 ram 1500? (meaning the arm rest console port in the enclosure.)
If so I might have to do this... If not... maybe not doesn't seem out of the way.
On my 2024 audio will only play from USB 1 and 2 which are in the dash.
Just confirmed my 22 will play from the 2 on center stack and 1 rear usb ( #3 Rear,Left). No go for center console port accepting usb for music.
Which file format do the song files need to be for the Ram?
Yea, usually the radio takes time to read and display the files. It won't show everything right away.
Apparently. What odd behavior. I've not experienced that with any other vehicle.
