2019 Bighorn 5.7 the starter button does not recognize either remote, i have to press button with remote to start the truck. All remote functions work as they should. Anyone else had this issue, i'm thinking issue with the push button.
Do they unlock the door fine? Have you checked the FOB battery? Do you have a rear window leak?2019 Bighorn 5.7 the starter button does not recognize either remote, i have to press button with remote to start the truck. All remote functions work as they should. Anyone else had this issue, i'm thinking issue with the push button.
do you have a rear window leak?All functions of both remotes work just fine the batteries in both are new, when i push the button i get key fob not detected message on the meter cluster.
truck battery is a little over a year old no other issues that would seem battery related, remote start works fine as does other remote functionsWhen's the last time the truck battery was replaced? Have you tested your current one?
2 of us asked you about the rear window. And you haven't answered that. There's a high chance it is the RF Hub in the rear.truck battery is a little over a year old no other issues that would seem battery related, remote start works fine as does other remote functions
yes i did it was repaired but appears to have started again would the leak effect just one function on the remotes,do you have a rear window leak?
or did you have a rear window leak?
It will definitely affect the starting of the truck.yes i did it was repaired but appears to have started again would the leak effect just one function on the remotes,
new batteries in both RKE's, everything functions on remotes but not being recognized by starter button until you press the starter button with RKEDo they unlock the door fine? Have you checked the FOB battery? Do you have a rear window leak?
year year halfWhen's the last time the truck battery was replaced? Have you tested your current one?
