hurricane motor
morganstl
I Pull a bass boat and sometimes a 12ft enclosed trailer with not much weight in it. Would the hurricane SO motor 1500 be fine for this or would I need to look at a HO?
You’d be fine with the Pentastar V6, so any uplevel engine will just be that much better.
Towing with a turbocharged engine is a revelation; the Hurricane would make the task effortless.
Ain't that the truth.
I pulled 3500# with my Santa Cruz. That 2.5 turbocharged 4-cyl 'only' put out 311 ft/lbs and power was never an issue at any sane speed, even going up mountains.
When things get heavy it's all the other stuff that's important: brakes, suspension, frame, etc.
The Hurricane SO puts out more power than the 6.4L on the HD's.
Depending on configuration (4x4 vs 4x2, bed length, gears, etc) the Hurricane is rated for 8,500-11,500 lbs.
