Ottocast car tv mate help please
Synner
Got it hooked up like it says, was able to find it in WiFi and hooked long enough to update firmware and did. Can’t get it to show anything on screen. Says connected but will not do anything and is staying red. Any advice to get this working?
I use their CarPlay/camera version for our toddlers car seat and it works pretty well. I don’t use it every time I drive as I just use it to the camera features and thus have to make sure my phone isn’t competing with it for CarPlay. I have found if i don’t get connected to it right at ignition then I’ll never connect to it until I shut down and start over.
.... I have found if i don’t get connected to it right at ignition then I’ll never connect to it until I shut down and start over. ...
The same thing happens to me.
I had to erase the connection memories between smartphones and trucks (on both of them reciprocally) and always use ottocast connected by wire to the truck and the smartphone only connected to ottocast (bt + wifi).
Sent by SM-F766B on Tapatalk
ok I will try this today, It would NEVER show on my phones BT only the wifi. I will delete my phone from the truck and my truck from my phone and try what you said. thank you for the reply.
Heck I have never got it to show anything on the screen. I must have tried 50 different times/ways yesterday. Will try what you and the post below this one says later. thanks for the reply
@Sinner, I answer to your mp. Try this:
Delete all connections (as mentioned even a little further up) then insert the ottocast plug into the USB1 socket.
Then... ottocast asks you if you want to connect to a smartphone or to an HDMI device.
If you want to watch videos, connect a memory containing a video and select HDMI.
It should work.
If you have an Android and you want to see full-screen car play, remember that your smartphone needs to be connected to ottocast only and with bt and wifi both active.
