Rough Country or Readylift 3.5" lift
Rammit
SE Michigan
They still look great either way...thanks for the pics.
A bit dirty but here’s a better side pic.
Our trucks are going to look similar :)
heres a couple better side pics. Excuse the salt all over it. Post some pics when you get it, look forward to seeing it.
Joeyp
Jersey Shore
Joeyp
Jersey Shore
Do you have the 3.21 or 3.92? Let me know if it helps out with your shift points. I see this may be an issue with the 3.21 gears and that's what I ordered...Missed that one!
Rammit
SE Michigan
I have the 3.92 rear. I’ll update once it’s on
Joeyp
Jersey Shore
Hey what are the differences between D & E load on the Nittos? I see similar sizes in both regular and metric but they weight a lot less....another thing to consider....look at the wight differences
LT285/65R20 E 127/124Q21735016.4 34.80 11.50 8.0-(8.5)-10.03860/3525@80 63.71
35x11.50R20LT E 124Q21729018.334.7611.428.0-(9.0)-10.53525@80 71.40
Rammit
SE Michigan
The load e range tires are heavier and have stiffer sidewalls snd higher weight ratings.
Rammit
SE Michigan
Did you have a chance to try it yet?
I just did today. I could not get my controller to work. After many calls to RC tech, they sent me out a new one. I programmed it this afternoon. I put in 35” and now the speedo is reading a little fast compared to my phone app. I am going to reprogram it tomorrow and see if I can fine tune it and get it closer. Once the controller actually worked, it was pretty easy.
Joeyp
Jersey Shore
How about the shift points?
Rammit
SE Michigan
I had to play with it a couple times but using 34” in the programmer seems pretty close to accurate. I don’t feel any difference in shift points. I don’t think it makes a lot of difference. My gas gauge and mpg readout should be a little more accurate now though.
Jplumley
They are completely tucked inside the wheel flares. I would prefer them flush or a touch proud of the flare but I go through some very nasty areas and wanted to protect from blasting the sides of the truck.
That’s the gloss finish I assume?
Foster432
Just got my 3.5” ready lift on with 33x12.50x22 nitto ridge grapplers (stock wheels). The ride is a little more stiff vs stock but not by much. It actually rides surprisingly well and the nittos are quite. They have a little higher pitched hum vs the Toyo m/t, but you have to turn the radio off and everything else to hear them. No rubbing issues anywhere. No trimming.
ghostface
Do you have any pictures of your setup? Super interested in seeing the 3.5 inch with 33's
