2025+ Trucks still have the rear water leak problem?
firemedic10584
Central Florida
Anyone with a 2025+ truck experience the common rear window / 3rd brake light leak yet? I'm wondering if I should be proactive and seal up my 3rd brake light and rear glass on my 2026 or has the issue seemed to have been solved?
I plan to apply sealant to my 2026 as soon as it warms up outside. I'm not sure if it is still a going concern, but it can't hurt to do it anyway.
After dealing with water intrusion into the racetrack tail light lens on my Durango (also a super common problem - notice how many you see on the road with the lower portion burned out), this issue is very familiar and is fixed using the same methods. There's some group of clowns in FCA engineering that clearly doesn't understand basic water-shedding design principles. The Durango has had this problem going back many years. I sealed up my Durango tail light and had no more problems.
I've not seen anyone post about 2025+ having this issue. The 3rd brake light issue was fixed along time ago. Hopefully, they fixed the rear window on the newer ones. I had it on my 2020 and dealer fixed it for free. No issues anymore.
Hi there, if you're experiencing this concern feel free to reach out to our team for support. We can check for any TSBs or extended warranties for this concern.
Diamond
Ram Cares
I have a 2025 Limited with no leaking issues (yet?)
I haven't had any water issues with my 2025 and I have had it for 19 months now. The third brake light has been off a couple times to switch out to LED's and still no leaks.
I have a 2026, what should I be looking for?
My rear window leak appeared after 4 years. Truck out of warranty. Cost me $445 for a new installation of a one piece glass. I’m not happy about this, but it’s the only problem I’ve had with the truck since day one. Other than the leaky rear glass, my 2021 1500 has been perfect.
Good to hear the issue seems to have been fixed after 2022/2023 trucks. I’m going to leave mine be. It’s also just a lease for now and I don’t intend to buy it out at the end since I always end up wanting to trade for a new one a couple years in. I’ll roll the dice with this one and see if anything happens.
Can you explain more on where the new sealant is to be applied?
Could be a couple of things. Most common is noticing wetness on the headliner above the back seat. Common causes were/are the 3rd brake light on the roof leaking, and, part of the frame around the window cracking. Shows a line in it similar to this picture (not mine - one I pulled from a Google image search).
I had a 2016 Sport & a 2021 Limited that never leaked - though the rear window did blow out all by itself on the limited a year & a half into ownership. No issues on my 26 Big Horn as of yet.
The rear window design was changed partway into the 2022 model year. Reports of leaks on trucks built after that are almost nonexistent.
Thank you. I try to not be negative towards ramcares on these forums. However, I can't help but to say that your post was astronomically more helpful than their "official" post.
