4WD Blinking Light / Not Engaging
IceyTys
Looking for some ideas here. I am getting the dreaded "Serv 4WD" blinking light and the system is not engaging. I tried looking up ideas on here and on YouTube but I've been w/o luck. I already replaced the front differential actuator with a replacement unit and no dice, still having the same issue. I was thinking of replacing the TCCM computer next, however when I am in neutral and I switch to 4WD I can hear the clicking going on down below, I would assume if I hear the clicks the TCCM is trying to switch into 4WD and thats not the culprit? Is there maybe a fuse or something I need to be looking for here?
Any help is appreciated.
Thanks.
Thanks.
Does it have any DTC`s?
Hi there, should you choose to visit the dealer regarding this concern, feel free to send our team a private message for an extra layer of support.
Diamond
Ram Cares
Diamond
Ram Cares
Thanks for reaching out, I am new to RAM. Would something like this fall under the power train warranty? 4WD system stop working? I am out of new car warranty, but maybe if this is something that might fall under powertrain I may take it to the dealer.
DTC's??? No other errors or check engine type lights. When I switch back to 2wd the Serv 4wd light resets, so no issues that I know of besides wont go into 4wd.
Something like that should store a trouble code, not necessarily turn on the check engine light.
Hi there, without an official dealer diagnosis our ability to discuss warrant coverage is limited. Feel free to send our team a private message to discuss further.
Diamond
Ram Cares
