2025 Ram 1500 Alignment Problems
Thank you Sir! I can do the SAS rest myself right? Or do I need to do this after alignment to make it work properly?
I have a '24 so haven't done it, but I assume you can do it.
Some procedures do need a scanner hooked up while doing adjustments, but I'm sure someone with more knowledge will add insight soon here.
FWIW, I had my tech "sweep the rack" when I had one of my multiple alignments done...it did not change anything. My truck continues pulling to the right, and my steering wheel actively turns itself to the right if I let it go.
2025 Ram with 3.5 inch lift has a slight pull to the right when letting go of steering or holding it straight. dealer couldn’t never get it aligned and tried 3 times (tsb also has been done) i took it to a 4x4 shop and they aligned it and stated its within specs.
You can't be serious..... they didn't do anything but turn the steering wheel.
Looks like that "Old" Toe shows the problem..excess In on one side excess Out on the other side..and "New" Toe is right on and even.👍
it still has a pull to the right. what do you think it could be? i have adjustable rear control arms as well as adjustable track bar.
Your numbers don't look back now..
Camber: slight +L, slight --R
Toe: slight +L/R and equal
Caster: questionable, should be ~4.7L and ~5.2R, but yours are opposite of that..not sure if that would cause a pull though(??).
I suppose your Rear Toe...slight --L and moderate +R could indicate a "crooked" axle, but that should cause a "dog tracking" of the rear end, not a front end pull(??).
I don't really know🤔
Caster pull is caused by the RH side being least positive/more negative than the LH side. That is the general rule.
so i should have them align it again to fix the caster on the right side. cause they were giving me the run around of why it could pull.
