2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
Thanks, I'm going to have a warranty inspection done.
Let us know what they say.
I plan on ordering a Laramie in a couple months. The only reason I am going Laramie instead of Big Horn is to get a power passenger seat. You can get just about any other option on the BH, but no power passenger seat.
Seems like all the car companies make you spend more on a higher trim package to get the power seat. There is no reason the power seat cannot be made an option since all the wiring is probably there.
Here's what worked for me to reset oil level after oil change;
wait one day, warm up engine for an hour, turn off, turn on without starting engine, turn off after about 2 minutes, start engine and oil light is off and display shows accurate oil level.
Yes. But the question is: Why? What’s the reason behind that decision?
I can’t figure it out. Or why the interior lighting stays on while the gate’s down.
For the lights, I’d say lazy programming (since the gate locks and unlocks with the door) for the charger… your gues is as good as mine
The Google Robot said this:
  • Key Fob/NFC Interference Mitigation: One of the most cited technical reasons for this specific behavior in newer vehicles across several brands (not just Ram) is preventing the electromagnetic field of the Qi charger from interfering with the Near Field Communication (NFC) or the passive entry/key fob detection systems. The truck needs to reliably detect where the key fob is (inside vs. outside the vehicle) to operate correctly. Disabling the charger during an "open door" state helps ensure accurate key detection.
But, also, it claims the interior light on with tailgate open is likely an intentional act to let you really know the gate is open 🤷🏻‍♂️🤨
This explanation seems reasonable. Everything can be improved, but the engineers made this choice.
Inviato dal mio SM-F766B utilizzando Tapatalk
The thing that I don't understand is why I can't turn off the trunk light (the one above the third brake light) in any way I've tried.
I mean: "turn off the light permanently until I will need it."
Has anyone heard of "Purge Valve Disconnect" recall, with recall number 90C ?
In my Ram app, I now have a "Campaign Satisfaction" tile between the Vehicle Report and Digital Glovebox tiles. It has a date of 12 November 2025 on the bottom of the tile. When I select the tile, I get a number of choices, with "Customer Satisfaction Notices" highlighted as having one item to check. Selecting this brings up a page that says "Parts Available". There is a link for "view PDF" and a Submit Reimbursement button. For the first few weeks, these were both dead-end links. Just yesterday I tried again, and this time it brought up a notification that I should bring the truck into a dealer to have the purge valve hose replaced.
A quick search online and I found TSB 09-025-25. Later today I'll pull the engine cover and check the hose. Supposedly I can check the color of a band on the latch to determine if it needs to be replaced.
I'm wondering why I had to stumble across this issue on an app on my phone, instead of being notified by some more direct means.
It's not a recall. Mine has not come off and has been tight every time I've checked it. The hose on my truck ends in AD
Technically not a safety recall, true. This is a Customer Service Notice (CSN) (or campaign). The Mopar Recall site, https://www.mopar.com/en-us/my-vehicle/recalls/search.html, is their clearing house website for safety recalls, emission recalls, customer satisfaction notices, and warranty extensions. This is an issue with the vehicle, and will be checked and repaired if necessary at no cost to the owner. Semantics aside, it's a type of recall.
I'll attach the notice I received and the related TSB.
I'm happy for you that hose has not come off and is tight. My truck has been driving fine, as well - but I checked the purge valve hose latch for the proper color, and found that it's dark gray and should be replaced. So while it's ok today, there's a risk that it might not be tomorrow. Or maybe when I'm some distance from home on a long trip. I'd rather follow the TSB and have it replaced. Note that there are two issues covered by this notice/TSB - the purge valve hose and the canister purge tube. The hose is identified by color (shades of gray, unfortunately), and the tube is identified by p/n, as you noted. Did you check the color of the HOSE latch on your truck, in addition to the p/n of the TUBE ?
Mine is gray, I've got the updated part number and I'll buy the hose when it's more readily available. Not worth spending a few hours for the dealership service to diagnose it, order the hose then have me bring the truck in a 2nd time.
We got the truck back from the dealership today. The dealer showed me a picture of what they said is the start/stop harness connector and it was unplugged. It's by the power distribution block. And they ordered a new passenger side mirror motor. They also mentioned that Ram told them to check the condition of seals in that area as they are pushing themselves out of connections. The dealer said that our truck didn't have that issue. As for the stuttering on take off it is still there. They didn't mention anything about a fix for it. So far the truck is driving good.
Good morning... do you have the part number? I'm considering whether i order the metal part from gruvenparts.com or a new motor for the next 100k km...
Wondering if anyone else experiences a high pitch whine noise after the truck has been shut off. I drove mine for a while today, and when I got home, I washed it (salt around here turned my red truck into a white one). While I was washing it, I heard the noise from the front of the truck. No, I didn’t pop the hood to try to track it down - I was trying to finish before dark. It seemed to stop once in a while, but I’m not 100% sure about that. This went on for at least 45 minutes. I had the key FOB in my pocket at first, and then i put it in the truck. No change. It doesn’t sound mechanical - like a coolant pump for turbos. It sounds more electronic.
Curious if this is normal for these trucks, of if there might be something wrong. (2025 Tungsten)
Mine has done this since I got it. I assumed it was normal as I have not had any issues to this point.
Thanks. I’ve assumed that, too - but figured I’d ask. I still get random gremlins from time to time. Like the error for the blind spot monitoring and the emergency braking. Luckily so far it resets after i shut off the truck and let it set for a few minutes.
I was having those random issues as well. The fix was one of two things. They replaced both batteries and updated the DCM to whatever the latest version is. The service rep said that having low batteries can cause errors the way I was experiencing. After they did both of those things, I haven’t had one of those issues again.
Hello all. I just made my way back to a 1500. My last 1/2 ton was a 2020 Ecodiesel which was my favorite truck I’ve ever had. Since then I had a Silverado 1 ton gasser for a couple years and a 2022 Ram Cummins for about 3 years. I made the switch back then because I was doing more towing which I’m not anymore. My truck is my daily driver so I put about 25k miles on a year. I wanted to go back to something that was more comfortable but still towing capable. I saw the great deals Ram had on the leftover 25’s this month so I did a build on their site and one came up on inventory that was the identical truck I built minus the bed utility group so I jumped on it.
It’s a 2025 Crew Cab 4x4 standard bed Big Horn. I can’t get the window sticker attached so that it’s readable. Options on the truck are towing technology group, trailer tow group, night edition, big horn level 2, front and rear rubber mats, 3.92 axle, black tubular side steps, engine block heater, surround view camera system. It appears that the crew cab standard bed must come standard with the 33gal tank too which I love. MSRP $66,015, purchase price $52,007. I drove my Cummins 5 hours to get the truck and drove the new truck home.
My quick thoughts are I love how comfortable, smooth, quiet, and powerful it feels. So far I love the I6. The interior is super nice and comfortable. As others have said I’m surprised at some of the things Ram is cheaping out on. My truck came with the tow mirrors and I don’t like that they aren’t power fold or extend, if you pay for the tow package and towing technology group it should have those options. It’s odd that the LED headlights don’t have the accent DRL anymore. The tail lights and 3rd brake light are halogen. Not a big deal to me just seems odd. Looks like my night edition wheels are not a true painted wheel either. They appear to have a black cap on them. Again not a big deal but another thing they cheaped out on. That being said for the price this truck has a ton of great options. I was smiling quite a bit on my 5 hour drive. Coming from almost 5 years of driving HD trucks daily it was just so comfortable and quiet. I think this truck set up for towing will be a better compromise for me than daily driving an HD truck just to tow 10 or less times a year.
