Is this normal?
Interestingly the owner's manual only mentions the MAX/MIN range on the bottle with respect to the 3.6L engine and recommends keeping the level between MAX and MIN when the engine is cold. The 3.6 and 3.0 both used pressurized tanks, so I would expect them to behave the same. The 5.7 has an unpressurized tank.
I'd leave it at whatever level it likes, as long as above MIN when cold, and see if it loses any more. If it settles at the MIN or above mark, I wouldn't worry about it.
With forced induction engines, the one you really need to watch is the intercooler coolant tank. If that starts dropping, it's almost surely the I/C brick leaking straight into your intake. I'm familiar with several cases of that, and it always ends in hydrolock and a new engine.
That’s good to know about. I’ve owned several turbocharged vehicles but none of them hade a liquid to air intercooler. I don’t really know anything about them. Am I correct in assuming that the intercooler coolant system is separate from the engine coolant system?
Yes, there's a smaller tank (same coolant) that feeds the intercooler. I have a TRX so the layout is different, but here's what mine looks like. It's the one on the left.
And here's a pic from the RHO. Small tank on the left (well, the right side of the engine bay).
Hey guys,
The coolant level in the recovery tank on my truck is always sitting at the "Min" level.
I have filled it to the Max line a couple of times so far. but, it goes to the min level after a few days.
Took it to the dealer a while back and they told me that the cant find any leaks.
I dont see (based on a surface) inspection any leaks
Thanks
can you check oil and make sure the oil looks good not milky ?
Thanks for the pics. When you say “same coolant” are you referring to the type of coolant or the two systems share the same coolant supply? I’m assuming the former and not the latter.
Same mix, you can pour a bottle of your favorite Mopar-only-OAT-expensive-as-sh1t coolant into both tanks. But yes, they're physically completely separate.
Hey guys,
I don't see (based on a surface) inspection any leaks
Thanks
If it never falls below the MIN mark when cold over an extended period of time, you are fine. If it falls below the MIN mark, replace what's lost, and check daily to see if it is loosing fluid and how much. If it is loosing daily then there is a problem. As long as there is fluid in the tank then it's safe, but the MIN mark shows that you are not pulling air into the system.
I'd drain it and check, be easier to check the dipstick but that ship has sailed. Sometimes with water/coolant in the oil it will precipitate on the underside of the oil filler cap so that's another spot to check.
..... Sometimes with water/coolant in the oil it will precipitate on the underside of the oil filler cap so that's another spot to check.
This happened sometimes on Hemi trucks. Now the turbo engine might have been designed very differently, don't you think?
Sent by SM-F766B on Tapatalk
I was suggesting another means of checking for emulsion other than draining the oil. Any internal combustion engine other than air cooled can experience coolant in the oil through any number of pathways.
Checked my reservoir today on my '25 Limited. Cold and hot the coolant is below the minimum mark and does not change.
I think I'll take it to the dealer and see if they'll top it off. I mentioned it when I got my oil changed back in June but they said it just fluctuates.
Apparently not!
