Raybestos. I have no idea if they are any good. but we will know soon. Probably makes no difference
I bought this last week and I was planning on using it unless it's a bad idea? It just looked bad with all the RTV on it. Plus I was able to clean some nasty stuff off the magnets
Happen to have a pn# for them? I like those!
Search Lube Locker gaskets to see if they have one for it. I use them on my LJ and they work great.
LubeLocker, LLC
In case anyone is paying attention to the diff gasket it doesn't fit. Not only did it not fit, it didn't even match the size they gave on Amazon.
If you look closely at the picture it shows a blurred section where LubeLocker logo would be. Its a bit suspicious seeing its twice as much for possibility the same thing. 😵‍💫
Thank you! I sent them an e-mail to verify. Amazon has that same one overnight.
Okay....here is what I received from them. Nothing can be this complicated. I understand though:
Thank you for your email.
I apologize for the links not working.
We don't refer part numbers due to liability.
Typically, for your 2020 RAM 1500, the rear diff is LLR-C925 If it has 12 bolts, and LLR-A105 if it has 14 bolts
Typically, for the front diff it is LLR-A925-12 if it has 12 bolts, and LLR-A925 if it has 14 bolts.
You may contact Summit Racing to confirm
They are our biggest distributor.
I am sorry, we don't have a tech available at this time.
SO I COUNTED 12 SO THAT MEANS GO WITH THE LLR-C925 If it has 12 bolts
that's why don't buy parts on amazon... cannot stress this enough.
i am assuming you meant you bought someting off amazon and it came and it doesn't fit lol.
The problem is you don't know what fits. You can't even get producer to commit to a model but they do suggest.
I ordered the correct one from Amazon overnight so I can finish this.
  • jl13
