Reverse Camera option/setting on 22+ UC5 w/surround view
PdPuNOme
5thGenRams Supporter
Jersey
In regards to 2022 and newer 1500's with the UConnect 5 system and Surround View cameras is there a way to turn on/off the surround view when in reverse? I find it useless and always reaching over to hit the reverse camera soft key as that is a far more useful view being 10x bigger. Is there a way to turn off the surround view or be able to at least auto turn on just the reverse camera when shifting into reverse?
Also, gridlines both dynamic and static have never worked during my ownership of this truck (preowned) all but once randomly did they appear, so have no history on the previous owners' doings. Any insight on that? Settings in BCM are correct and within the radio, tried everything including battery disconnect, bcm reset, radio hard reset, radio soft reset, cleared all settings and restarted fresh... nothing has done the trick. Software is the 27 variant.
To follow up from my original post, I was able to resolve the gridline issue, found that the "offroad front camera" was enabled which did offer a soft key for it in all the camera screens which was nice, but had that adverse effect as it for whatever reason messed with the surround view. Turned that off and gridlines reappeared along with the surround view calibration.
Still would love for it to default to just the reverse camera view when in reverse with the option to switch to surround view not the opposite or way it is by default. I would believe the only way to do so is to disable the surround view all together.
My friend is trying to solve this problem by activating the off-road camera without losing the panoramic view, among other things 1500 2022 with 14.5 inch screen
